    LoadFile(Filename file) does not work for layouts.
    c++r20windows
    8 Posts 2 Posters 2.6k Views 1 Watching
    • O Offline
      Ogers
      I am trying to load a layout (.l4d file extension) using LoadFile() function but when I do this the Cinema4D will open with the loaded layout active, and then stop working. when I try to load other files like .c4d it loads them correctly.
      Am I doing something wrong here or is there another way to do this?
      Thank you.
        hello,
        From where are you trying to switch the layout ?
        I've tested on the script manager and in the command line and it's working just as expected.
        If you want Cinema4D to launch with a particular layout you can also use the -layout argument.
        I'm waiting your feedback to have a chance to reproduce your issue.
        I'm assuming you are using the version R20.059.
        • O Offline
          Ogers
          Hello @m_magalhaes
          I am putting the code under C4DPL_BUILDMENU.
          case C4DPL_BUILDMENU:
             Filename file = Filename("C:/Program Files/MAXON/Cinema 4D R20
             Education/library/layout/myLayout.l4d");
             LoadFile(file);
             break;
          I am using R20.028 but I don't think this changes anything. Maybe I am just putting the code on the wrong place.
          Thank you
            Several things here,
            your path on windows should use backslash (\) and not slash (/)
            and you should have two.
            "C:\\Program Files\\MAXON\\Cinema 4D R20 Education\\library\\layout\\myLayout.l4d"
            A better way to do this is to use operator so your path will be compatible with all OS.
            // Create a filename to point to "Application directory/library/layout/Animate.l4d"
            const Filename file = GeGetStartupPath() + Filename("library") + Filename("layout") + Filename("Animate.l4d");
            // load the layout.
            Bool result = LoadFile(file);
            // check the result.
            if (!result)
            	DiagnosticOutput("can't load the layout");
            I've tested this code in PluginMessage() using C4DPL_COMMANDLINEARGS and C4DPL_PROGRAM_STARTED
            O 1 Reply Last reply Reply Quote 3
            • O Offline
              Ogers @Manuel
              I tried the code that you have tested but I am still having the same problem. As I have mentioned in the beginning the layout does load but then Cinema4D stops working (Not Responding)
                @m_magalhaes said in LoadFile(Filename file) does not work for layouts.:
                That's why i mention those PluginMessage ids.Sorry, I forgot to say If you use that code in C4DPL_BUILDMENU Cinema4D will stop working (or throw an exception if you are in debug mode for an "Acces Violation Reading Location")
                Are you still in C4DPL_BUILDMENU ?
                O 1 Reply Last reply Reply Quote 1
                • O Offline
                  Ogers @Manuel
                  Yes I tried with the mentioned PluginMessage ids but I tried only on C4DPL_PROGRAM_STARTED and it stopped working so I thought the other will not work as well.
                  I tried C4DPL_COMMANDLINEARGS now and this one only seems to work for me.
                  Thank you πŸ™‚
                    Again sorry, I've tested with the Studio version.
                    Using C4DPL_PROGRAM_STARTED case I can confirm this "bug" with a Educational version and a Demo version.
                    Not with the Studio version.
                    Maybe something with that extra "popup" windows on those both versions.
                    Manuel.
