    Change LONG_CYCLE selected Item.
    c++r20windows
    11 Posts 8 Posters 2.8k Views 2 Watching
    • O Offline
      Ogers
      I am creating a CUSTOMGUI_CYCLE with my own attributes using getDDescription function. Everything goes fine until the point where I want to change the selected item. Assume that I have the following code, the Item with id 0 will be selected by default. Is there any way that I can change this? Like after a specific action the Item 1 will be selected? I tried many things but I could not find the right one. the .SetInt32(Id,value) method does not seem to work for this case as well.I also tried GetDParameter and other possible ways to do this but still could not solve this.
        BaseContainer settings = GetCustomDataTypeDefault(DTYPE_LONG);
        settings.SetString(DESC_NAME, "Drop Down"_s);
        settings.SetInt32(DESC_CUSTOMGUI, CUSTOMGUI_CYCLE);
        // add cycle elements
        BaseContainer items;
        items.SetString(0, "Item 1"_s);
        items.SetString(1, "Item 2"_s);
        items.SetString(2, "Item 3"_s);
        settings.SetContainer(DESC_CYCLE, items);
      Thank you.
      J H 2 Replies Last reply Reply Quote 0
        hello,
        You can set the default value you want in your Init function.
        In any case, the Cycle will show the value corresponding to the value of the parameter.
        #define MY_CYCLE_ID 1000
        class DefaultCycleValue : public ObjectData
        	INSTANCEOF(DefaultCycleValue, ObjectData)
        	virtual Bool Init(GeListNode *node)
        		// set the parameter the value we want, the Custom GUI will show the corresponding line in the box.
        		node->SetParameter(DescID(MY_CYCLE_ID), GeData(1), DESCFLAGS_SET::NONE);
        		return true;
        	virtual Bool GetDDescription(GeListNode* node, Description* description, DESCFLAGS_DESC& flags) override
        		if (!description->LoadDescription(node->GetType()))
        			return false;
        		const DescID* singleid = description->GetSingleDescID();
        		const DescID cid = DescLevel(MY_CYCLE_ID, DTYPE_LONG, 0);
        		if (!singleid || cid.IsPartOf(*singleid, nullptr))
        			// add the parameter as long
        			BaseContainer bc = GetCustomDataTypeDefault(DTYPE_LONG);
        			// set the custom GUI to a cycle.
        			bc.SetInt32(DESC_CUSTOMGUI, CUSTOMGUI_CYCLE);
        			bc.SetString(DESC_NAME, "Long Cycle"_s);
        			bc.SetInt32(DESC_SCALEH, 1);
        			// cycle elements
        			items.SetString(0, String("Item 0"));
        			items.SetString(1, String("Item 1"));
        			items.SetString(2, String("Item 2"));
        			bc.SetContainer(DESC_CYCLE, items);
        			// icons
        			BaseContainer icons;
        			icons.SetInt32(0, IDM_COPY);
        			icons.SetInt32(1, IDM_CUT);
        			icons.SetInt32(2, IDM_DELETE);
        			bc.SetContainer(DESC_CYCLEICONS, icons);
        			description->SetParameter(cid, bc, ID_OBJECTPROPERTIES);
        		flags |= DESCFLAGS_DESC::LOADED;
        		return SUPER::GetDDescription(node, description, flags);
        	static NodeData *Alloc() { return NewObjClear(DefaultCycleValue); }
        • O Offline
          Ogers
          Thank you @m_magalhaes
          • J Offline
            JeffreyZimmerman @Ogers
            This post is deleted!
              HectorSmallwood @Ogers
              Everything goes fine until the point I want to change the selected item. Assume that I have the following code, the Item with id 0 will be selected by default. Is there any way that I can change this? Like after a specific action the Item 1 will be selected?
              event to determine when the selected item in the ListBox is changed.
                hello @HectorSmallwood
                @HectorSmallwood said in Change LONG_CYCLE selected Item.:
                That's exactly what the code is doing in the Init() function using SetParameter(). You change the value of the parameter, the UI show the item with that value in the list. So by default the parameter value is 1 so the UI show the item with the value 1 "Item 1"
                If you want to change the item somewhere else, same thing just change the value of the parameter, the ui will follow.
                I'am adding an answer here as it is a related. But for your second question if the answer doesn't fit your need, please open a new thread and post your question in a new thread. That will help us to keep things organized.
                If i understand the question, you have to check for MSG_DESCRIPTION_CHECKUPDATE message type in the Message() function as follow.
                virtual Bool Message(GeListNode* node, Int32 type, void* data) override
                		switch (type)
                			case MSG_DESCRIPTION_CHECKUPDATE :
                				DescriptionCheckUpdate* dcu = static_cast<DescriptionCheckUpdate*>(data);
                				if (dcu == nullptr)
                					return true;
                				maxon::Int32 id = (*(dcu->descid))[0].id;
                				if (id == MY_CYCLE_ID)
                					DiagnosticOutput("Cycle have been changed");
                						// ... do Something
                				break;
                		return true;
                W 1 Reply Last reply Reply Quote 0
                • W Offline
                  williamgutierrez @Manuel
                  • CairynC Offline
                    Cairyn
                    Am I the only one who sees three posts in this thread defaced by insertions of spam into a valid post?
                      mogh
                      yesterday I saw 2 small triangles which i didn't unfold .... today they are gone... addblocker at work ?
                        thanks for pointing those spam. I cleaned them
                        • W Offline
                          walthenry
                          Thanks for guiding
                          Regards,
                          Folexin
