    Set Keyframes through a Python Tag
    r20python
    9 Posts 2 Posters 3.0k Views 1 Watching
    • B Offline
      bentraje
      I need to set a keyframe through a python tag. This means if I change something a frame and a value in the code, it updates in the affected object.
      I watched this
      . It also uses a python tag but unfortunately, once you set the keyframe, you have to modify it on the timeline rather than within the code.
      Here is my code so far, assuming a simple primitive cube in the scene:
      def set_keyframe(obj, objParameter, frameList, valueList):
          old_tracks = obj.FindCTrack(objParameter)
          # Remove existing track and create a new one. This ensures that the only track available in the object is within the code
          if old_tracks:
              old_tracks.Remove()
          new_track = c4d.CTrack(objParameter)
          obj.InsertTrackSorted(new_track)
          curve = atrck.GetCurve()
          # This is the part that I don't know what I'm doing.
          for (frame,value) in zip(frameList,valueList):
              curve.AddKey (c4d.BaseTime(frame, 24))
              atrck.FillKey(doc, obj, value )
      set_keyframe(
          obj = doc.SearchObject("Cube"),
          objParameter = c4d.ID_BASEOBJECT_REL_POSITION,c4d.VECTOR_Y, # Assuming the selected object is
          frameList = [0,30,45],
          valueList = [100,-250,20]
      Is there a way around this?
      Thank you for looking at the problem.
        Hi @bentraje.
        First of all, I would like to remind you a Python Tag is executed at every scene execution. And modify the current scene representation (aka adding a keyframe, changing object data) while the scene execution may lead to some change not being correctly synchronized.
        Moreover, this means for each frame you will modify this, so there is probably a better way for doing it, depending on your need. Maybe through a button user data? That can be caught in the Message methods.
        Regarding how to creates keyframe take a look at the next example. Written for the script manager.
            # Searches if there is already an existing Track for this parameter.
            track = obj.FindCTrack(objParameter)
            # Removes the track if it's already here.
            if track is not None:
                track.Remove()
            # Creates a new track for this parameter.
            track = c4d.CTrack(obj, objParameter)
            # Inserts the track into the object
            obj.InsertTrackSorted(track)
            # Retrieves the curve representation of this track
            curve = track.GetCurve()
            # Iterates over the frame list and the valueList (count have to be the same)
            for (frame, value) in zip(frameList, valueList):
                # Calculates the equivalent of a BaseTime for a given frame
                time = c4d.BaseTime(frame, obj.GetDocument().GetFps())
                # Creates a keyframe in the memory
                key = c4d.CKey()
                # Fills the key with the default data
                track.FillKey(doc, obj, key)
                # Defines the y value
                key.SetValue(curve, value)
                # Defines the time value
                key.SetTime(curve, time)
                # Adds a key on the curve for the given frame
                curve.InsertKey(key)
        # Main function
            set_keyframe(obj = doc.SearchObject("Cube"),
                         objParameter = c4d.DescID(c4d.DescLevel(c4d.ID_BASEOBJECT_REL_POSITION), c4d.DescLevel(c4d.VECTOR_Y)),
                         valueList = [100,-250,20])
        # Execute main()
        If you have any question, please let me know.
        • B Offline
          bentraje
          @m_adam
          Thanks for the response! You are right, I guess a normal script should do the job.
          Quick question:
          How do I set the interpolation to spline? I tried the following code at the end of the for loop in the def set_keyframes:
          key.SetInterpolation(curve, 2)
          Interestingly. There is no error in the Python Console but it is still on a linear interpolation.
            Try to use another value since symbols c4d.CINTERPOLATION_LINEAR is equal to 2 so it's normal if the interpolation is defined to linear.
            Take a look at the CKey.SetInterpolation methods to know which symbols are expected.
            • B Offline
              bentraje
              @m_adam
              Thanks for the response.
              I tried this one again at the end of the for loop in the def set_keyframes:
              key.SetInterpolation(curve, c4d.CINTERPOLATION_SPLINE)
              It doesn't error out but it's also not in the spline interpolation.
              Am I missing something?
                Which version are you? Here is working nicely
                Maxime
                • B Offline
                  bentraje
                  @m_adam
                  I'm using R20.059. Looking at it now, it seems like, yes, it is on spline interpolation.
                  The problem is the "Ease In/Ease Out" is not enabled.
                  I can set it using the SetTimeLeft() and SetTimeRight() but this would mean hardcoding a value. I can't hard code it since the Ease In/Ease Out depends on how far the next and previous frames are.
                  Is there a command that set that values automatically? The same where you click the "Ease In/Ease Out" command in timeline editor.
                    Unfortunately, this is not possible. EaseIn/Out commands are not exposed.
                    But you could define the key as auto tangents, clamp and remove overshooting, which make the same result here.
                            key.ChangeNBit(c4d.NBIT_CKEY_AUTO, c4d.NBITCONTROL_SET)
                            key.ChangeNBit(c4d.NBIT_CKEY_REMOVEOVERSHOOT, c4d.NBITCONTROL_SET)
                            key.ChangeNBit(c4d.NBIT_CKEY_CLAMP, c4d.NBITCONTROL_SET)
                    Otherwise, you have to calculate and define the correct value using SetTimeLeft/Right.
                    • B Offline
                      bentraje
                      @m_adam
                      Gotcha. Work as expected.
                      Have a great day ahead!
