    how to write description "Coordinates"
    c++r20
    6 Posts 3 Posters 1.3k Views 1 Watching
      mike
      how to write description "Coordinates"? i use 9 independent data to accept it but it looks like error(see R.H,no alignment).
      hope your help!
        mp5gosu
        Hey mike,
        you can use a parent group with 3 columns layout and then for each column, put it into a speparate group to maintain constant width.
        M 1 Reply Last reply Reply Quote 1
          mike @mp5gosu
          @mp5gosu Thank you! is useful☺
            hello,
            thanks @mp5gosu for the answer.
            To add something here, you can have a look at the file r_info_manager.res, that's the coordinate manager. This have to be reproduce the same way in a CreateLayout.
            On a description, things are a bit easier you can use a customGUI CUSTOMGUI_SUBDESCRIPTION
            on the .res file juste add this line
            VECTOR ID_BASEOBJECT_REL_POSITION { UNIT METER;  CUSTOMGUI SUBDESCRIPTION; }
            on the GetDDescription you juste add a vector and specify the customGUI to use
            		DescID cid = DescLevel(vectorID, DTYPE_VECTOR, 0);
            			// check if this parameter ID is requested (NOTE: this check is important for speed)
            			if (!singleid || cid.IsPartOf(*singleid, nullptr))
            				// define the new parameter description
            				BaseContainer settings = GetCustomDataTypeDefault(DTYPE_VECTOR);
            				settings.SetString(DESC_NAME, "A vector"_s);
            				settings.SetInt32(DESC_CUSTOMGUI, CUSTOMGUI_SUBDESCRIPTION);
            				// set the new parameter
            				if (!description->SetParameter(cid, settings, ID_OBJECTPROPERTIES))
            					return false;
            Of course, you can add vector in userData the same way.
                bc = c4d.GetCustomDataTypeDefault(c4d.DTYPE_VECTOR)
                bc.SetString(c4d.DESC_NAME, "Parameter Name")    # displayed in the Xpresso "Object" node
                bc.SetString(c4d.DESC_SHORT_NAME, "Short Name")  # displayed in the Attribute Manager
                bc.SetInt32(c4d.DESC_CUSTOMGUI, c4d.CUSTOMGUI_SUBDESCRIPTION)
                op.AddUserData(bc)
            M 1 Reply Last reply Reply Quote 2
              mp5gosu
              @m_magalhaes Huh, nice. But is this documented somewhere?
              edit: Nevermind, found it. πŸ™‚
                mike @Manuel
                @m_magalhaes thank you for your answer πŸ™‚
