    Cannot modify Lens Effects
    3 Posts 2 Posters 889 Views 1 Watching
    • S Offline
      sean
      I want to change the lens effets Settings, but I can't. I'm using python.
      Why is that? Is there any other way? Can you provide sample code? Thank you very much!
      code:
          lightObj = op.GetObject()
          print "Assignment before: 'col' = ", lightObj[c4d.LIGHT_LENSEFFECTS_GLOW].streak[0]['col']
          lightObj[c4d.LIGHT_LENSEFFECTS_GLOW].streak[0]['col'] = c4d.Vector(1, 0, 0)
          print "Assignment After: 'col' = ", lightObj[c4d.LIGHT_LENSEFFECTS_GLOW].streak[0]['col']
      result:
      Assignment before: 'col' =  Vector(0, 0, 0)
      Assignment After: 'col' =  Vector(0, 0, 0)
        Hi @sean, first of all, welcome in the plugincafe community.
        So the main issue is light[c4d.LIGHT_LENSEFFECTS_GLOW] returns you a copy of the GlowStruct and GlowStruct.streak also return you a copy of the list (unfortunately this can't be changed it's on our implementation for some safeties reason).
        So here is how to do it.
        def UpdateStreak(light, streakId, color):
            # Retrieves the copy of the glow struct
            glowStruct = light[c4d.LIGHT_LENSEFFECTS_GLOW]
            # Retrieves the copy of the list
            streakList = glowStruct.streak
            if streakId >= len(streakList):
                raise ValueError("Streak Id is bigger than the number of streak.")
            # Defines the color
            streakList[streakId]['col'] = c4d.Vector(1, 0, 0)
            # Defines the modified list of streak
            glowStruct.streak = streakList
            # Defines the modified GlowStruct
            light[c4d.LIGHT_LENSEFFECTS_GLOW] = glowStruct
            print "Assignment before: 'col' = ", op[c4d.LIGHT_LENSEFFECTS_GLOW].streak[0]['col']
            UpdateStreak(op, 0, c4d.Vector(1, 0, 0))
            print "Assignment After: 'col' = ", op[c4d.LIGHT_LENSEFFECTS_GLOW].streak[0]['col']
        # Execute main()
        Documentation will be improved.
        Finally, few rules, don't worry I've setup correctly your topic since its the first one, but please try to follow them for your next topics.
        - Q&A New Functionality.
        - How to Post Questions.
        If you have any question, please let me know.
        S 1 Reply Last reply Reply Quote 1
        • S Offline
          sean @m_adam
          @m_adam Thank you. Thank you very much!
