    Modify FBX Exporter?
    r20python
    5 Posts 2 Posters 1.3k Views 1 Watching
    • B Offline
      bentraje
      I have a problem in Cinema4D where it converts periods into underscores upon FBX export.
      You can see an illustration of the problem here:
      https://www.dropbox.com/s/newsmvxv2fdhbsx/c4d085_cinema_fbx_export_convert_problem.jpg?dl=0
      Previously, I initially shrug it off but currently I'm working with a pipeline that requires proper naming convention. As such, I need to have it as periods and not as undercores?
      So far what I have is a modified code from the OBJ exporter sample file. See below.
      However, I am still no clue where to investigate the unusual conversion of "." to "_"
      I did check the FBXexport.res file in the installation directory but it mostly offers booleans parameter/arguments.
      Is there a way around this?
      from c4d import documents, plugins, storage
      #Author: Joey Gaspe
      #OBJ export settings example
          # Get OBJ export plugin, 1030178 is its ID
          plug = plugins.FindPlugin(1030178, c4d.PLUGINTYPE_SCENESAVER)
          if plug is None:
          # Get a path to save the exported file
          filePath = c4d.storage.LoadDialog(title="Save File for OBJ Export", flags=c4d.FILESELECT_SAVE, force_suffix="obj")
          if filePath is None:
          op = {}
          # Send MSG_RETRIEVEPRIVATEDATA to OBJ export plugin
          if plug.Message(c4d.MSG_RETRIEVEPRIVATEDATA, op):
              print op
              if "imexporter" not in op:
              # BaseList2D object stored in "imexporter" key hold the settings
              objExport = op["imexporter"]
              if objExport is None:
              # Define the settings
              # Example of OBJ export settings from the UI:
              objExport[c4d.OBJEXPORTOPTIONS_TEXTURECOORDINATES] = True
              objExport[c4d.OBJEXPORTOPTIONS_MATERIAL] = c4d.OBJEXPORTOPTIONS_MATERIAL_MATERIAL
              # objExport[c4d.] =
              # export without dialogs
              if c4d.documents.SaveDocument(doc, filePath, c4d.SAVEDOCUMENTFLAGS_DONTADDTORECENTLIST, 1030178):
                  print "Document successfully exported to:"
                  print filePath
                  print "Export failed!"
        Hello @bentraje ,
        I'm afraid this is hard coded and there's no option to avoid this. The rename have been added to fix a bug with Maya and XSI. ("same base name is causing issues in Maya and XSI")
        You can try to export the fbx in a text format (this is an option) and to rename back every object in the file. I know it's far to be ideal but for now, i have nothing else in mind.
        • B Offline
          bentraje
          @m_magalhaes
          Thanks for the clarification. Yes, I guess the text format will be an alternative for now.
          Have a great day ahead!
            hello,
            can we consider your issue as "solved" ?
            • B Offline
              bentraje
              Sure sure we can label at as solved at the moment.
              Thanks again for the help!
