    Modifying or Adding Script Directory?
    r20python
    5 Posts 3 Posters 1.2k Views 2 Watching
    • B Offline
      bentraje
      By default, the script folder is pointed to library>scripts.
      Is there a way to modify or add additional directory?
      For instance, changing it to a network location or on a dropbox directory so it would be easy to edit, update and readily use scripts rather than going to the script manager and open the script every time I make a change on it.
      Is this possible?
      Thank you for looking at the problem.
        On windows, you can create an environment variable named C4D_SCRIPTS_DIR more informations in the doc
        The doc say : Multiple paths can be separated using a semicolon (;) but it's seem buggy at the moment, i have to investigate a bit further and i'll be back if i found something.
        On OSX you don't have environment variables but you can create a Symbolic Link (not an alias). You have to use the Terminal to do so (ln -s /<source>/myscript.py /<preferences path>/library/scripts) This will create a link in your scripts directory.
        I've tried to link from directory to directory but it doesn't work.
        • B Offline
          bentraje
          @m_magalhaes
          I am not sure about the multiple paths
          But having only a singular path, it works as expected.
          Closing this thread for now.
          Thank you. Have a great day ahead!
            thanks a lot and happy to learn your issue is solved.
            About the multi-path separated with semicolon, I can confirm it is bugged at the moment but will be fixed in the next release.
            • M Online
              This issue is now fixed in R21.
