    IsEqual not defined
    r20c++
    3 Posts 2 Posters 675 Views 2 Watching
    • C4DSC Offline
      C4DS
      I get a compiler error, and can't seem to wrap my head around the actual problem
      Say I have the following code (reduced to a dummy minimum for purpose of demonstration):
      #include "c4d.h"
      class Int32Pair
      	Int32Pair() : a(0), b(0) {}
      	Int32Pair(const Int32& _a, const Int32& _b) : a(_a), b(_b) {}
      	virtual ~Int32Pair() {}
      private:
      	Int32 a;
      	Int32 b;
      class Test
      	Test()
      		maxon::BaseArray<Int32Pair> somedata;
      		if (somedata == mPairArray)
      			// do something
      	~Test() {}
      private:
      	maxon::BaseArray<Int32Pair> mPairArray;
      Basically, I have two arrays of Int32Pair which I want to compare, but compiler gives me a
      error C2338: IsEqual not defined.
      Which I have narrowed done as being caused by the line
      Where should this IsEqualbe defined?
      Inspired by the SortedArray example I tried adding an IsEqual into the Int32Pair class as:
      static maxon::Bool IsEqual(const Int32Pair& p1, const Int32Pair& p2) { return (p1.a == p2.a) && (p1.b == p2.b); }
      But compiler still complains about IsEqual not being defined.
      As such, I am guessing it's the BaseArray which needs to be defined with a compare method. But how? Have tried looking into the BaseArray manual, but failed to find any answer.
      I would appreciate an example showing how it needs to be done. Thanks in advance.
        you have to define the operator == in your class Int32pair.
        For this you have a macro that help, it will implement both == and != operator.
        class Int32Pair
        	MAXON_OPERATOR_EQUALITY(Int32Pair, a, b);
        private:
        	Int32 a;
        	Int32 b;
        Let me know if it solve the problem 🙂
        • C4DSC Offline
          C4DS
          @m_magalhaes said in IsEqual not defined:
          Thanks, didn't know about the MAXON_OPERATOR_EQUALITY. Very handy indeed.
          However, I had already tried providing an equality operator in my Int32Pair class, as such:
          Bool operator == (const Int32Pair& other) { return (a == other.a) && (b == other.b); }
          But that still resulted in the "IsEqual not defined" compiler error.
          The macro, however, is working fine.
          Looking further at my implementation of operator==, I now notice I didn't declare it as a const method. Adding the const does get rid of the compiler error. Oh boy! Overlooked a minor "typo", with major consequences.
          Again, thanks for the macro.
