    Copy link object
    r20c++
    4 Posts 2 Posters 1.4k Views 1 Watching
    • A Offline
      anoano
      Hi.
      I copied the object of link field in the virtual object with GetClone ().
      However, if the type of the linked object is a generator type such as instance, it can not be displayed properly below the linked object on the object manager.
      I checked past posts and found that they have priority issues.
      But I do not know how to solve it.
      https://developers.maxon.net/forum/topic/6250/6615_clone-of-a-linked-object
      Please let me know if anyone knows who you are.
        Hi @anoano.
        I will need more information.
        I'm not sure in which context you are, when you say virtual object I think you refer to be inside of a Generator and the GetVirtualObjects method isn't?
        Moreover, when you say a link, you refer to a LinkBox parameter, so the linked object can be anywhere and not necessary a Child of the current Generator, isn't?
        Last stuff, please make sure to mark your topic as a question. I've done it for this time (don't worry you are new, no issue at all), see Q&A New Functionality.
        • A Offline
          anoano
          Re: Copy link object
          This is the code I wrote.
          BaseObject *HyperINS::GetVirtualObjects(BaseObject *op, HierarchyHelp *hh)
                  BaseContainer* bc = op->GetDataInstance();
          	BaseObject* main = BaseObject::Alloc(Onull);
          	if (!main) return nullptr;
          	BaseObject    *link= (BaseObject*)bc->GetLink(ID_LINK, hh->GetDocument());
          	if (!link) return main;
          	AutoAlloc<AliasTrans> aliastrans;
                  if (!aliastrans || !aliastrans->Init(hh->GetDocument())) return main;
                  BaseObject* ref = static_cast<BaseObject*>(link->GetClone(COPYFLAGS::NONE, nullptr));
                  aliastrans->Translate(true);
                  ref->InsertUnder(main);
          	return main;
          It will not work at the manager's position.
          alt text
          alt text
            Hi, the topic is now marked as solved, did you solve your issue?
            The only workaround I was able to find is to make use of AddToExecution and define it to GENERATOR+1, here you retrieve and clone the cache of the linked object in a member variable of your instance, then in the next GVO you make use of this cache, but this has the application that you work always on a mesh that has been generated in a previous SceneExecution call, which may be an issue in case of animation.
