    Python - Cinema 4D R20.057 - Export to Alembic without Dialog
    pythonr20
    6 Posts 2 Posters 1.7k Views 1 Watching
    • P Offline
      PdZ
      Hi all,
      i know the example on github. I tried to export to alembic. But the alembic-file is not written and I don't get any error. If I set the parameter to "c4d.FORMAT_ABCEXPORT" nothing changes. Only when I use "c4d.FORMAT_C4DEXPORT" it writes a file. But thats not what I want. When I use the script on Github and change the "filePath" to an actual path it works only with c4d Export. But not with Alembic.
      I wonder what I do wrong. Heres the code:
      Export Settings Example
      This example shows how to change an exporter settings.
      This works also for importers/scene loaders.
      from c4d import documents, plugins, storage
          # Get Alembic export plugin, 1028082 is its ID
          plug = plugins.FindPlugin(1028082, c4d.PLUGINTYPE_SCENESAVER)
          if plug is None:
          # Get a path to save the exported file
          filePath = "D:\\a.abc"
          if filePath is None:
          op = {}
          # Send MSG_RETRIEVEPRIVATEDATA to Alembic export plugin
          if plug.Message(c4d.MSG_RETRIEVEPRIVATEDATA, op):
              if "imexporter" not in op:
              # BaseList2D object stored in "imexporter" key hold the settings
              abcExport = op["imexporter"]
              if abcExport is None:
              # Change Alembic export settings
              abcExport[c4d.ABCEXPORT_SELECTION_ONLY] = True
              abcExport[c4d.ABCEXPORT_PARTICLES] = True
              abcExport[c4d.ABCEXPORT_PARTICLE_GEOMETRY] = True
              # Finally export the document
              if documents.SaveDocument(doc, filePath, c4d.SAVEDOCUMENTFLAGS_DONTADDTORECENTLIST, c4d.FORMAT_ABCEXPORT):
                  print "Document successfully exported to:"
                  print filePath
                  print "Export failed!"
      Btw: I don't get any error. And if I change the parameter "c4d.FORMAT_ABCEXPORT" back to "1028082" doesnt change anything. And I dont want to get a dialog either.
      It's the same with the simple code below:
          filePath = "D:\\hallo.abc"
          c4d.documents.SaveDocument(doc, filePath, c4d.SAVEDOCUMENTFLAGS_DONTADDTORECENTLIST, c4d.FORMAT_ABCEXPORT)
      Thx in advance!
        Hi @PdZ, are you sure you get the permission(Cinema 4D) to write directly into a drive folder? Could you try on your desktop or any other one that you are sure is writable?
        • P Offline
          PdZ
          Dear m_adam,
          thx for your response. Iam pretty sure C4D has permission to write but weirdly enough it only happens with exports other than .c4d.
          Fortunately I was able to use R20 new feature to write alembics out by using the build in function "save as alembic and delete".
            Hi @PdZ I'm not able to reproduce it, in a folder I do have the right to write, both success, in a folder I do not have the right to write both fails.
            Could you try for a folder where you are sure your user is allowed to write such as a temp folder?
              @PdZ does it's solved?
              • P Offline
                PdZ
                Yes it is! Thank you very much!
