    Retrieve the World Rotation of a Selected Edge?
    r20python
    4 Posts 3 Posters 1.3k Views 1 Watching
    • B Offline
      bentraje
      I'm trying to align a window on a wall. But the wall is angled and I'm having a problem determining the proper orientation.
      You can see an illustration of problem here:
      https://www.dropbox.com/s/j6rqbvokopn3b6h/c4d084_align_angled_rotation_properly.mp4?dl=0
      I was thinking of getting the world rotation of the selected edge, but the coordinate manager does not seem to show anything. You can see the attempt here:
      https://www.dropbox.com/s/z03x7faykja0u9c/c4d084_align_angled_rotation_properly.jpg?dl=0
      Is there a way to retrieve it using Python?
      Thank you for looking at the problem
        mp5gosu
        Hi @bentraje,
        do you need that functionality to work in GUI mode? If so, here's an example video showing that Cinema 4D already provides that funtionality - a bit hidden though:
        In P/S/R tool with a selected object, Ctrl+RightClick an axis (or rotation band). Release both to hover over a reference point, edge, axis, etc.
        Left-Click and drag to a target point.
        Another workaround I also use often, are guides. Set a guide to semi-line, so you have start - and end-handles. Snap the guide to the edge or angled wall.
        Now you can either use Guide-Snapping or simply copy/paste the rotation.
        The third solution would be to use dynamic guides.
        Best,
        Robert
        • B Offline
          bentraje
          Thanks @mp5gosu for the illustration. Works as expected.
            hello,
            To answer this question if someone want to do it by code.
            from c4d import gui
            # Main function
                #get the selected object
                op = doc.GetActiveObject()
                if not op:
                    raise TypeError("there's no object selected")
                if not op.IsInstanceOf(c4d.Opolygon):
                    raise TypeError("obj should be a polygon object")
                #setup neighbor
                nbr = c4d.utils.Neighbor()
                nbr.Init(op)
                #get the selected edge
                bs = op.GetSelectedEdges(nbr,c4d.EDGESELECTIONTYPE_SELECTION)
                #maximum number of edge should be number of polygon * 4
                sel = bs.GetAll(op.GetPolygonCount() * 4)
                #get all polygon
                vadr = op.GetAllPolygons()
                #init point a and b index to -1 for error check
                a = b = -1
                #initialise a counter to check in sel array.
                countEdge = 0
                #we can check now every edge to find the corresponding points. So for each polygon
                for i in xrange(op.GetPolygonCount()):
                    #get the polygon information
                    pli = nbr.GetPolyInfo(i)
                    for side in xrange(4): # Test all 4 sides of a polygon
                        # Only proceed if edge is marked
                        # and edge really exists (for triangles side 2 from c..d does not exist as c==d)
                        if pli["mark"][side] or (side==2 and vadr[i].c == vadr[i].d):
                            continue
                        #if the edge is marked as selected in our sel array
                        if sel[countEdge]:
                            if side==0:
                                a=vadr[i].a; b=vadr[i].b
                            elif side==1:
                                a=vadr[i].b; b=vadr[i].c
                            elif side==2:
                                a=vadr[i].c; b=vadr[i].d
                            elif side==3:
                                a=vadr[i].d; b=vadr[i].a
                        countEdge +=1
                if a == -1 or b == -1:
                    raise ValueError("points index can't be negatives")
                #get all points array
                points = op.GetAllPoints()
                #Get the direction of the edge in global coordinate (multiply the points'vector by the matrix of the object)
                opmg = op.GetMg()
                #i've picked a direction from point a to point b so the angle could need to be reverted.
                dirVector = points[b]*opmg - points[a]*opmg
                #normalize a vector is often a good idea.
                dirVector.Normalize()
                #transform the vector to hpb note the result is in radian
                hpb = c4d.utils.VectorToHPB(dirVector)
                #transform radian to degree
                hpb.x = c4d.utils.RadToDeg(hpb.x)
                hpb.y = c4d.utils.RadToDeg(hpb.y)
                hpb.z = c4d.utils.RadToDeg(hpb.z)
                print "the edge is poiting to",dirVector,"the corresponding angle is", hpb
            # Execute main()
