    Cinema Gradient, weird behaviour
    r20sdkpython
    7 Posts 2 Posters 1.4k Views 1 Watching
    • P Offline
      PdZ
      Hi all,
      I encountered a very weird behaviour. I tried to write a script in python which reads all the knot-values of one gradient and set those value to another gradient.
      I can read the knots by calling GetKnot().
      BUT when I try to extract a certain info from a Knot (for example the position) I get wrong results. So when transfering these infos to another gradient, the gradient is shown wrong.
      Thats the Code:
      from c4d import gui
          mat = doc.GetFirstMaterial()           #Gets the first material in the materials manager
          shdr1 = mat[c4d.MATERIAL_COLOR_SHADER]
          shd = c4d.BaseList2D(1011100) # Gradient
          mat[c4d.MATERIAL_DIFFUSION_SHADER] = shd
          mat.InsertShader(shd)
          mat.Message(c4d.MSG_UPDATE)
          mat.Update(True, True)
          shdr2 = mat[c4d.MATERIAL_DIFFUSION_SHADER]
          grad1 = shdr1[c4d.SLA_GRADIENT_GRADIENT]
          grad2 = shdr2[c4d.SLA_GRADIENT_GRADIENT]
          grad1_knot1 = grad1.GetKnot(0)
          print("Knot1 = " + str(grad1_knot1))
          grad1_knot2 = grad1.GetKnot(1)
          print("Knot2 = " + str(grad1_knot2))
          grad1_knot3 = grad1.GetKnot(2)
          print("Knot3 = " + str(grad1_knot3))
          index1 = grad1_knot1['index']
          print("Index" + " " + str(index1))
          index2 = grad1_knot2['index']
          print("Index" + " " + str(index2))
          index3 = grad1_knot3['index']
          print("Index" + " " + str(index3))
          pos1 = grad1_knot1['pos']
          print("Position" + " " + str(pos1))
          pos2 = grad1_knot2['pos']
          print("Position" + " " + str(pos2))
          pos3 = grad1_knot2['pos']
          print("Position" + " " + str(pos3))
          col1 = grad1_knot1['col']
          print("Color" + " " + str(col1))
          col2 = grad1_knot2['col']
          print("Color" + " " + str(col2))
          col3 = grad1_knot2['col']
          print("Color" + " " + str(col3))
          bri1 = grad1_knot1['brightness']
          print("Brightness" + " " + str(bri1))
          bri2 = grad1_knot2['brightness']
          print("Brightness" + " " + str(bri2))
          bri3 = grad1_knot2['brightness']
          print("Brightness" + " " + str(bri3))
          grad2.FlushKnots()
          grad2.InsertKnot(col=col1, pos=pos1,index=index1)
          grad2.InsertKnot(col=col2, pos=pos2,index=index2)
          grad2.InsertKnot(col=col3, pos=pos3,index=index3)
          shdr2[c4d.SLA_GRADIENT_GRADIENT] =  grad2
      # Execute main()
      And thats the result I get from the console and obviously the second gradient looks like that (wrong), too.
      "Knot1 = {'index': 1, 'bias': 0.5, 'pos': 0.3, 'col': Vector(1, 1, 1), 'brightness': 1.0}
      Knot2 = {'index': 2, 'bias': 0.5, 'pos': 1.0, 'col': Vector(1, 1, 1), 'brightness': 1.0}
      Knot3 = {'index': 3, 'bias': 0.5, 'pos': 0.5, 'col': Vector(1, 0.6, 0.5), 'brightness': 1.0}
      Index 1
      Index 2
      Index 3
      Position 0.3
      Position 1.0
      Position 1.0
      Color Vector(1, 1, 1)
      Brightness 1.0
      Brightness 1.0
      Brightness 1.0
      As you can see: When calling GetKnot() the infos of the Knots are right. But when extracting for example col of those Knots, The results are wrong. They all show Vector(1, 1, 1).
      What is happening here?
      PdZ
      • P Offline
        PdZ
        I coded a solution. But this was so much work and effort to get it work.
        Its not very sexy though. BUT it works.
        from c4d import gui
            grad1_knot1 = str(grad1.GetKnot(0)).replace("'", "").replace(":", " =").replace("Vector", "c4d.Vector").replace("{", "").replace("}", "")
            grad1_knot2 = str(grad1.GetKnot(1)).replace("'", "").replace(":", " =").replace("Vector", "c4d.Vector").replace("{", "").replace("}", "")
            grad1_knot3 = str(grad1.GetKnot(2)).replace("'", "").replace(":", " =").replace("Vector", "c4d.Vector").replace("{", "").replace("}", "")
            print(grad1_knot1)
            # index
            newgrad1_knot1_index_nr = grad1_knot1.find(",")
            newgrad1_knot1_index = int(grad1_knot1[newgrad1_knot1_index_nr-1:newgrad1_knot1_index_nr])
            # bias
            newgrad1_knot1_bias_nr = grad1_knot1.find(",", newgrad1_knot1_index_nr+1 )
            newgrad1_knot1_bias = float(grad1_knot1[newgrad1_knot1_bias_nr-3:newgrad1_knot1_bias_nr])
            # color
            newgrad1_knot1_col_nr = grad1_knot1.find("col")
            newgrad1_knot1_col_nr2 = grad1_knot1.find("brig")
            newgrad1_knot1_col = grad1_knot1[newgrad1_knot1_col_nr+6:newgrad1_knot1_col_nr2-2]
            newgrad1_knot1_col_1komma = newgrad1_knot1_col.find(",")
            newgrad1_knot1_col_2komma = newgrad1_knot1_col.rfind(",")
            newgrad1_knot1_col_ende = newgrad1_knot1_col.find(")")
            vector_value_1 = float(newgrad1_knot1_col[11:newgrad1_knot1_col_1komma])
            vector_value_2 = float(newgrad1_knot1_col[newgrad1_knot1_col_1komma+2:newgrad1_knot1_col_2komma])
            vector_value_3 = float(newgrad1_knot1_col[newgrad1_knot1_col_2komma+2:newgrad1_knot1_col_ende])
            # position
            newgrad1_knot1_pos_nr = grad1_knot1.find("pos")
            newgrad1_knot1_pos = float(grad1_knot1[newgrad1_knot1_pos_nr+6:newgrad1_knot1_col_nr-2])
            # brightness
            newgrad1_knot1_bri_nr = len(grad1_knot1)
            newgrad1_knot1_bri = float(grad1_knot1[newgrad1_knot1_col_nr2+13:newgrad1_knot1_bri_nr])
            grad2.FlushKnots()
            grad2.InsertKnot(index = newgrad1_knot1_index, bias = newgrad1_knot1_bias, pos = newgrad1_knot1_pos, col = c4d.Vector(vector_value_1, vector_value_2, vector_value_3), brightness = newgrad1_knot1_bri)
        # Execute main()
          Hi, @PdZ in which version are you, using R20 with the first code works as expected, could you share a scene example?
            @PdZ any news?
            • P Offline
              PdZ
              Hi Adam,
              thx for your response!
              Sorry I was busy. Didn't meant to let you wait.
              Iam working with:
              Cinema 4D Studio R20 20.059
              Heres the testscene:
              gradient_test.c4d
              Heres the code:
              from c4d import gui
                  grad2.FlushKnots()
              # Execute main()
              Here is what I get as gradient in the Diffusion shader:
              There are 3 Knots. 2 at the same position on the right side.
              Also the console tells me that result:
              Thx in Advance!
              PdZ
              • P Offline
                PdZ @PdZ
                @PdZ
                Ok adam,
                iam a stupid idiot. I had a typo.
                Pls ignore everything. I checked the code and I set values of knot 2 to knot 3.
                Iam sorry!
                  Don't feel sorry yes this is the issue and since Knot ID are not ordered from right to left but from creation order its why it's confused you.
                  Moreover, using a for loop will make way more sense and help you to avoid this kind of stuff.
                      for knotId in xrange(grad1.GetKnotCount()):
                          knot = grad1.GetKnot(knotId)
                          grad2.InsertKnot(col=knot['col'], pos=knot['pos'],index=knot['index'])
                      grad2.FlushKnots()
                  Finally, a BaseShader is derived from BaseList2D which is derived from C4DAtom that mean you can use GetClone to retrieves a clone of this shader so your code can look like.
                      colorShader = mat[c4d.MATERIAL_COLOR_SHADER]
                      if colorShader is None:
                      copyColor = colorShader.GetClone()
                      mat[c4d.MATERIAL_DIFFUSION_SHADER] = copyColor
                      mat.InsertShader(copyColor)
                  # Execute main()
