    Understanding SetCommandDragId
    6 Posts 2 Posters 1.1k Views 1 Watching
    • lasselauchL Offline
      lasselauch
      I'm having troubles to understand the SetCommandDragId function for c4d.gui.BitmapButtonCustomGui.
      I'm using the following function to add my BitmapButton to my Dialog:
          def AddIconButton(self, buttonid, title, iconid, tooltip):
              bc = c4d.BaseContainer()
              bc.SetBool(c4d.BITMAPBUTTON_BUTTON, True)
              bc.SetInt32(c4d.BITMAPBUTTON_ICONID1, iconid)
              bc.SetString(c4d.BITMAPBUTTON_TOOLTIP, tooltip)
              bc.SetInt32(c4d.BITMAPBUTTON_FORCE_SIZE, 32)
              button = self.AddCustomGui(buttonid, c4d.CUSTOMGUI_BITMAPBUTTON, title, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, 40, 40, bc)
              #set button.SetCommandDragId() here?!!!
              return button
      Even inside the CreateLayout I had no luck with FindCustomGUI() ...
      What's the best way to approach this?
      Lasse
        lasselauch
        I must add:
        Either they are dragable to the layout or I'm only able to press within the dialog...
          Hi yes, the behavior changes a bit once you defined the BitmapCustomGui as a Button that can be dragged.
              def CreateLayout(self):
                  bc.SetInt32(c4d.BITMAPBUTTON_ICONID1, c4d.Ocube)
                  button = self.AddCustomGui(10003, c4d.CUSTOMGUI_BITMAPBUTTON, "but", c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, 40, 40, bc)
                  button.SetCommandDragId(c4d.Ocube)
              def Message(self, msg, result):
                  if msg.GetId() == c4d.BFM_INTERACTEND:
                      if self.IsActive(10003):
                          print 'Icon clicked in the GeDialog.'
          Note that if you click on the icon directly from the Cinema 4D palette it will automatically call the CallCommand with the correct it.
            lasselauch
            Thanks so much, @m_adam!
            Works like a charm!
            Lasse
              lasselauch
              Just to reconcile:
              button.SetCommandDragId(THIS_ID) -> THIS_ID needs to be a unique PluginID, correct?
              Lasse
                Correct, and I would say a CommandData id.
