    Porting plugin to R20, disable style guide?
    4 Posts 2 Posters 1.2k Views 1 Watching
    • F Offline
      FilipM
      Hi!
      I am finally taking the plunge and moving my development to R20. To get started I am porting an old plugin to R20. I have successfully compiled the sdk examples for R20. However, when compiling my own plugin, I get errors related to the style guide, e.g.:
      error : Style guide requires whitespace before =.
      The "projectdefinition.txt" file for my plugin looks as follows:
      // Supported platforms - can be [Win64;OSX]
      Platform=Win64;OSX
      // Type of project - can be [Lib;DLL;App]
      Type=DLL
      // API dependencies
      APIS=cinema.framework;mesh_misc.framework;math.framework;crypt.framework;python.framework;core.framework;
      // C4D component
      C4D=true
      stylecheck=false
      //stylecheck.level=0 // must be set after c4d=true
      stylecheck.enum-registration=false
      stylecheck.enum-class=false
      // Custom ID
      ModuleId=com.filipmalmberg.solidchamfer
      I thought the setting stylecheck=false would disable the stylecheck completely? Am I doing something wrong?
      Best regards
      /Filip
      • S Offline
        s_bach
        using
        stylecheck=false
        or
        stylecheck.level=0
        disables the style check. But then you write:
        which apparently turns the stylecheck on again. So if you remove these two lines, style check should be disabled.
        You can also turn errors into warnings using stylecheck.aswarnings=true.
        • F Offline
          FilipM
          Thanks Sebastian, I will try that!
          /Filip
          • F Offline
            FilipM
            This post is deleted!
