    Python: Key Error while initializing GUI, Dictionary, self
    5 Posts 2 Posters 1.2k Views 1 Watching
      mogh
      "Dictionary" "self" and old SDK sample code might be my issue, but can somebody help me and point out, why I get a key error by just adding more gui elements to this old SDK ToolData plugin liquid-painter sample code.
      adding a Checkbox (Bool) worked, but adding other gui elements breaks the smaple code somehow.
      Key error on line 39 & 107 (marked in the Code so you don't need to search)
      Thanks in advance
      R20 Visualice
      import os
      from c4d import gui, plugins, bitmaps
      # be sure to use a unique ID obtained from www.plugincafe.com
      PLUGIN_ID = 1015073
      # for GeLoadString values must match with the header file
      IDS_PRIMITIVETOOL = 50000
      class SettingsDialog(gui.SubDialog):
          parameters = None
          def __init__(self, arg):
              self.parameters = arg
          def CreateLayout(self):
              self.GroupBegin(id=1000, flags=c4d.BFH_SCALEFIT, cols=2, rows=5)
              self.GroupBorderSpace(1, 1, 1, 1)
              # Bool
              self.element = self.AddStaticText(id=2003, flags=c4d.BFH_SCALEFIT, initw=1, name="Extend Vector: ", borderstyle=c4d.BORDER_NONE)
              self.element = self.AddCheckbox(id=2002, flags=c4d.BFH_SCALEFIT, initw=1, inith=0, name="")
              #valuebool = self.parameters['extend_vector']
              self.SetBool(2002, False)
              # Extension Value
              self.element = self.AddStaticText(id=3001, flags=c4d.BFH_SCALEFIT, initw=1, name="Extension Ratio: ", borderstyle=c4d.BORDER_NONE)
              valueextension = self.parameters['extension_ratio']
              self.AddEditSlider(id=3002, flags=c4d.BFH_SCALEFIT)
              self.SetFloat(id=3002, value=valueextension, min=0.1, max=100, step=0.1, min2=0.0001, max2=1000, quadscale=True)
              print self.parameters
              self.element = self.AddStaticText(id=1001, flags=c4d.BFH_SCALEFIT, initw=1, name="Sphere Size: ", borderstyle=c4d.BORDER_NONE)
              valuespheresize = self.parameters["sphere_size"]
      # first key error
              self.AddEditNumberArrows(id=1002, flags=c4d.BFH_SCALEFIT)
              self.SetFloat(id=1002, value=valuespheresize, min=0, max=20)
              self.GroupEnd()
          def Command(self, id, msg):
              if id == 1002:
                  self.parameters['sphere_size'] = self.GetFloat(1002)
                  print "Sphere Size: ", self.GetFloat(1002)
              if id == 2002:
                  self.parameters['extend_vector'] = self.GetBool(2002)
                  print "Extend Vector:", self.GetBool(2002)
              if id == 3002:
                  self.parameters['extension_ratio'] = self.GetFloat(3002)
                  print "Extension Ratio: ", self.GetFloat(3002)
      class AVTTool(plugins.ToolData):
          # Inherit from ToolData to create your own tool
          def __init__(self):
              self.data = {'sphere_size': 15}
              self.data = {'extension_ratio': 1}
          def GetState(self, doc):
              if doc.GetMode() == c4d.Mpaint: return False
              return c4d.CMD_ENABLED
          def Debug(self, msg):
              # c4d.CallCommand(13957) # Konsole loeschen
              print "Konsole geloescht."
          def KeyboardInput(self, doc, data, bd, win, msg):
              key = msg.GetLong( c4d.BFM_INPUT_CHANNEL )
              cstr = msg.GetString( c4d.BFM_INPUT_ASC )
              if key == c4d.KEY_ESC:
                  # do what you want
                  print "ESC Key Pressed."
                  # return True to signal that the key is processed
              return False
          def MouseInput(self, doc, data, bd, win, msg):
              mx = msg[c4d.BFM_INPUT_X]
              my = msg[c4d.BFM_INPUT_Y]
              device = 0
              if msg[c4d.BFM_INPUT_CHANNEL] == c4d.BFM_INPUT_MOUSELEFT:
                  device = c4d.KEY_MLEFT
              elif msg[c4d.BFM_INPUT_CHANNEL] == c4d.BFM_INPUT_MOUSERIGHT:
                  device = c4d.KEY_MRIGHT
              null = c4d.BaseObject( c4d.Ometaball )
              null[c4d.METABALLOBJECT_SUBEDITOR] = 10
              null.MakeTag( c4d.Tphong )
              doc.AddUndo( c4d.UNDO_NEW, null )
              doc.InsertObject( null )
              doc.SetActiveObject( null )
              c4d.DrawViews( c4d.DA_ONLY_ACTIVE_VIEW | c4d.DA_NO_THREAD | c4d.DA_NO_ANIMATION )
              rad = self.data['sphere_size']
      # second key error
              dx = 0.0
              dy = 0.0
              win.MouseDragStart( button=device, mx=int( mx ), my=int( my ),
                                  flags=c4d.MOUSEDRAGFLAGS_DONTHIDEMOUSE | c4d.MOUSEDRAGFLAGS_NOMOVE )
              result, dx, dy, channel = win.MouseDrag()
              while result == c4d.MOUSEDRAGRESULT_CONTINUE:
                  mx += dx
                  my += dy
                  # continue if user doesnt move the mouse anymore
                  if dx == 0.0 and dy == 0.0:
                      continue
                  cl = c4d.BaseObject( c4d.Osphere )
                  cl.SetAbsPos( bd.SW( c4d.Vector( mx, my, 500.0 ) ) )
                  cl[c4d.PRIM_SPHERE_RAD] = rad
                  cl.InsertUnder( null )
              if win.MouseDragEnd() == c4d.MOUSEDRAGRESULT_ESCAPE:
                  doc.DoUndo( True )
          def GetCursorInfo(self, doc, data, bd, x, y, bc):
              if bc.GetId() == c4d.BFM_CURSORINFO_REMOVE:
              bc.SetString( c4d.RESULT_BUBBLEHELP, plugins.GeLoadString( IDS_PRIMITIVETOOL ) )
              bc.SetLong( c4d.RESULT_CURSOR, c4d.MOUSE_POINT_HAND )
          def AllocSubDialog(self, bc):
              return SettingsDialog( self.data )  # always return new instance
          bmp = bitmaps.BaseBitmap()
          fn = os.path.join(dir, "res", "AligntoVector.tif")
          bmp.InitWith(fn)
          plugins.RegisterToolPlugin( id=PLUGIN_ID, str="Py-AlignToVector",
                                      info=0, icon=bmp,
                                      help="Select two Points to generate a Vector. Then Click additional points to move them onto the Vector.",
                                      dat=AVTTool() )
      • S Offline
        s_bach
        as always, please use the Q&A system and also tell us the version of Cinema 4D you are using.
        There is no issue with adding GUI elements. The issue is with these lines of code:
        Please make sure you understand how to use a Dictionary in Python.
          mogh
          Thanks Sebastian,
          I did read your dictionary link but was wondering why then this code works in the sample sdk
          what i've tried so far to set or read the dic. in the init
                  self.data["sphere_size"] = 15
                  self.data["extension_ratio"] = 1
                  self.data.get("sphere_size")
                  self.data.get("extension_ratio")
                  self.data = parameters["sphere_size"] = 15
                  self.data = parameters["extension_ratio"] = 1
                  self.data = parameters.get("sphere_size")
                  self.data = parameters.get("extension_ratio")
                  self.data = {'sphere_size': 15}       # original SDK Code !
          This is obviously a problem of myself understanding the concept of "self" but I really like to learn by solving c4d problems instead of generic Phyton lessons.
          kind regards mogh
          R20 Visualize
          • S Offline
            s_bach
            this isn't a Cinema 4D issue; it has also nothing to do with "self". It is just about understanding basic Python syntax.
            Just run this code
            someDict = { "a", 1}
            someDict = { "b", 2}
            print(someDict)
            to see that it only contains one key/value pair. This is because the second line does not add a key/pair value. The assignment operator overwrites the variable with a new Dictionary.
            I strongly recommend do to some generic Python lessons.
              mogh
              thanks solved:
              self.data = {'sphere_size': 15, 'extension_ratio': 1, 'extend_vector': False}
              kind regards
