    Developing .obj sequence exporter for selected objects
    12 Posts 5 Posters 5.3k Views 1 Watching
    • mikeudinM Offline
      mikeudin
      May be Polygonize can help you.
      Make a clone of the document and turn all objects into polygon based objects.
      https://mikeudin.net
      P 1 Reply Last reply Reply Quote 1
      • a_blockA Offline
        a_block
        I'm afraid I need to apologize, my answer was actually by some discussion we had internally and I was too confused to read properly again. Sorry. Maybe @mikeudin's answer can already help. We'll look into this tomorrow again.
        • a_blockA Offline
          a_block
          Hello @Polyflow,
          we thought a bit more about your request. Unfortunately I had no time, yet, to do some tests here.
          In general we think, my last answer should at least be part of a solution of the problem.
          In regards to "polygonizing" or "baking", this should actually be just a matter of correctly retrieving the cache of an object in the executed document. Please take a look at GetDeformCache() and GetCache(). Again also the C++ docs have some more info on this: BaseDocument manual - Cache.
          Andreas
          • P Offline
            Polyflow @mikeudin
            @mikeudin
            Polygonize not works for me.
            By the way - I'm amazed at the responsiveness of your community.
            • P Offline
              Polyflow
              Now i am trying to Bake an object before export using Current State To Object but this test piece of code not do anything
              res = utils.SendModelingCommand(command = c4d.MCOMMAND_CURRENTSTATETOOBJECT,
                                              list = [op],
                                              mode = c4d.MODELINGCOMMANDMODE_ALL,
                                              doc = doc)
                mp5gosu
                Hi @Polyflow,
                did you try the example here? Also, please keep an extra eye on the note that's written below there.
                You have to first clone your object via GetClone() and pass this as to your object list.
                For example, I'm using this code in one of my plugins at work (there's a lot of error-handling stuff missing though):
                # current state to object
                def csto(op):
                    if op is None:
                        return False
                    doc = op.GetDocument()
                    if doc is None:
                        return False
                    pred = op.GetPred()
                    parent = op.GetUp()
                    settings = c4d.BaseContainer()
                    settings.SetBool(c4d.MDATA_CURRENTSTATETOOBJECT_INHERITANCE, True)
                    newOp = c4d.utils.SendModelingCommand(command=c4d.MCOMMAND_CURRENTSTATETOOBJECT,
                                                          mode=c4d.MODELINGCOMMANDMODE_ALL,
                                                          list=[op.GetClone()],
                                                          doc=doc,
                                                          bc=settings)
                    if newOp:
                        doc.AddUndo(c4d.UNDOTYPE_NEW, newOp[0])
                        doc.InsertObject(newOp[0], parent, pred)
                    return False
                and
                for polygonizing the document:
                # Polygonize document, respecting instances in the right order, returns new document
                def polygonize(doc):
                    if doc is None:
                        return None
                    op = doc.GetFirstObject()
                    oldObjects = []
                    while op:
                        if op.IsInstanceOf(c4d.Oinstance):
                            # check and convert instances
                            oldObjects.append(op)
                            csto(op)
                        op = GetNextObject(op)
                    for op in oldObjects:
                        doc.AddUndo(c4d.UNDOTYPE_DELETE, op)
                        op.Remove()
                    return doc.Polygonize()
                You have to resolve the instances before using this code, though.
                Hope, this helps you a bit.
                P 1 Reply Last reply Reply Quote 2
                • P Offline
                  Polyflow @mp5gosu
                  @mp5gosu i am unsuccessfully trying code from documentation.
                  I’m the developer of Vertex Animation Tools for Unity, I can’t say that I'm new to tool development, but this API makes me feel stupid. I saw the Polygonyze function, but I don’t see its result. I'm really trying to understand the C4D API in reasonable term but I can't. Exporting the obj sequence from c4d is a trivial function that people have been looking for for years, and now I understand why.
                  Can Maxons engineers helps to write this script (finally)?
                  • mikeudinM Offline
                    mikeudin
                    To see the results of Poligonize method you have to insert resulting document.
                    • a_blockA Offline
                      a_block
                      @Polyflow: MAXON's SDK Team can only help and assist you in achieving your goal. Writing complete scripts and plugins is not within our mandate.
                      With that said, what about my answer regarding caches? Can you give us some more details on the issues you have with this approach?
                      Andreas
                      • B Offline
                        bentraje
                        Probably not that helpful but there is an existing script for the C4D OBJ Sequence Exporter
                        https://richh.co/c4d-native-obj-sequence-export-no-plugins/
