    Retrieve the newly created object from the "IK_TAG_ADD_GOAL" command?
    r20python
    5 Posts 2 Posters 1.3k Views
    • B Offline
      bentraje
      I have this code that clicks the "Add Goal" in the IK Tag. This creates a null that corresponds to the goal. Is there a way to access this null after creation?
      Currently I have this:
      IKGoal = c4d.CallButton(IKTag, c4d.ID_CA_IK_TAG_ADD_GOAL)
      print(IKGoal)
      #returns NONE rather than the Null IK Goal
      It creates a newly created Null object that represents the IK Goal but when I print(IKGoal), it results to none rather than the Null IK Goal.
      Is there a way around this?
      Thank you for looking at the problem
      • S Offline
        s_bach
        using CallButton() is the same as pressing the button in the GUI. So the CallButton() function does not return anything.
        The "Add Goal" functionality creates a new Null object. This null object is inserted after the host object of the tag. Sou you could simply get the "next" object to get the goal object.
        tag = doc.GetActiveTag()
        if not tag:
        # should check for type of course
        c4d.CallButton(tag, c4d.ID_CA_IK_TAG_ADD_GOAL)
        # assume that the newly created null object is now the next object after the host object
        hostObject = tag.GetObject()
        nextObject = hostObject.GetNext()
        print(nextObject)
        Alternatively, you could simply read the now defined BaseLink to the goal object:
        goalObject = tag[c4d.ID_CA_IK_TAG_TARGET]
        B 1 Reply Last reply Reply Quote 3
        • B Offline
          bentraje @s_bach
          @s_bach
          Thanks for the revised script Sebastian. I tried both code and it worked as expected.
          But may I ask an additional question:
          Where did you retrieved this: [c4d.ID_CA_IK_TAG_TARGET]?
          I cannot find it in the documentation. It's not also present in the script log. Whenever I modified it, it only appears with a cryptic number: 10001
          I like it because it's descriptive and helps me understand the code better.
          • S Offline
            s_bach
            you can drag and drop parameters into the Python console. Then you will see the parameter symbol.
            See Python Console.
            • B Offline
              bentraje
              Gotcha. Thanks for clarification!
