    Get points within a given radius
    4 Posts 3 Posters 1.0k Views 1 Watching
    • orestiskonO Offline
      orestiskon
      Hi all,
      is there a python function to get the points of an object within a given radius of a defined position?
      I can iterate through all the points but this can get costly.
        Hi Orestis,
        Unfortunately, all helpers classes available in C++ such as KDTree, DistanceQueryInterface or either VoxelizationInterface are not available in Python. So the only reliable way is to iterates over all the points like so.
        import sys
        # Main function
            start = time.time()
            if not op: return
            if not isinstance(op, c4d.PointObject): return
            # WorldPosition to Match
            posToMatch = c4d.Vector(25, -13, -88)
            # Retrieves points position in World Position
            opMat = op.GetMg()
            pts = [pt * opMat for pt in op.GetAllPoints()]
            if not pts: return
            # Iterates overs all list to find the closest point
            nearestDist = sys.float_info.max
            ptId = None
            for x, pt in enumerate(pts):
                dist = (pt - posToMatch).GetLength()
                if dist >= nearestDist: continue
                nearestDist = dist
                ptId = x
            print nearestDist, ptId
        # Execute main()
        I have also tested to do some threading stuff, but due to the GIL in python, this does not bring any performance gain (even worse).
          orestiskon
          Thanks Maxime, that clears it out.
            mp5gosu
            You may want to consider to use scipy.
            You have to do indexing once, but can the efficiently iterate over the points within a desired radius with the functions that come with the module.
