    R20 equivalent of GeSignal
    r20sdkc++
    7 Posts 3 Posters 2.2k Views 1 Watching
    • P Offline
      peterakos
      Hello.
      In Cinema 4D R19, I was using GeSignal instead of while/GeSleep to "wake up" a thread.
      Which is the equivalent in maxon API ?
      Thank you.
      • S Offline
        s_bach
        to "wake" a thread one should use a condition variable. You find information in the Condition Variables Manual. General information on threading with the MAXON API is found here: MAXON API Threading.
        • P Offline
          peterakos
          Hello and thank you very much for the help.
          It appears that I cannot use it in a custom thread that inherits C4DThread.
          I have a private member maxon::ConditionVariableRef, but the following call fails compilation:
          condition = maxon::ConditionVariableRef::Create();
          Do I have to use it only in a thread inheriting maxon::ThreadInterfaceTemplate<ExampleThread> ?
          Thank you.
          S 1 Reply Last reply Reply Quote 0
          • S Offline
            s_bach @peterakos
            @peterakos said in R20 equivalent of GeSignal:
            what compilation error exactly do you get?
            • P Offline
              peterakos
              Hello.
              Here is the error:
              error C2679: binary '=': no operator found which takes a right-hand operand of type 'maxon::ResultMemTmaxon::ConditionVariableRef' (or there is no acceptable conversion)
              note: could be 'maxon::ConditionVariableInterface::Reference &maxon::ConditionVariableInterface::Reference::operator =(const maxon::ConditionVariableInterface::Reference &)'
              note: or 'maxon::ConditionVariableInterface::Reference &maxon::ConditionVariableInterface::Reference::operator =(maxon::ConditionVariableInterface::Reference &&)
              I have used it exactly as in ConditionVariable manual, but the thread is C4DThread instead of maxon::ThreadInterfaceTemplate<ExampleThread>.
              Thank you.
              • r_giganteR Offline
                r_gigante
                Hi Peterakos, thanks for following up.
                It seems that the issue you're reporting is related to the fact that you're not properly handling the result of the BaseRef::Create() with the usual error handling means.
                Please check Error handling in our the C++ API Documentation.
                Best, Riccardo
                • P Offline
                  peterakos
                  Hello.
                  The problem was that I didn't add the definitions.
                  iferr_scope;
                  signal = maxon::ConditionVariableRef::Create() iferr_return;
                  Thank you for your time and sorry for that 😞
