    Time Limit for MSG_DESCRIPTION_CHECKUPDATE
    5 Posts 2 Posters 1.2k Views 1 Watching
    • merkvilsonM Offline
      merkvilson
      Hello PluginCafe! 🙂
      I need to apply SetDirty() function only after finishing the manipulation process of the desired parameter.
      Something like this is implemented in the material preview.
      The update takes place only after ~0.5 seconds after finishing the manipulation.
      alt text
      So, I tried to check updates via MSG_DESCRIPTION_CHECKUPDATE and calculate the time by utilizing timeit module
              start = timeit.default_timer() #Start Timer
              if type == c4d.MSG_DESCRIPTION_CHECKUPDATE:
                  if data["descid"][0].id == TEST_SLIDER: #Check if TEST_SLIDERis updated
                      end = timeit.default_timer() #End Timer
                          if end - start > 1: #Do something if time took more than 1 sec
                              self.bmp.SetDirty()
                              node.SetDirty(c4d.DIRTYFLAGS_DATA)
      But unfortunately, I can't find the solution in the documentation.
      What am I doing wrong and how to do this properly?
      • S Offline
        s_bach
        you could react to the message MSG_DESCRIPTION_USERINTERACTION_END which is sent after the user stopped interacting with the parameter in the Attribute Manager.
        You find a list of related messages in the NodeData::Message() Manual.
          merkvilson
          Is this feature available for Python?
            merkvilson
            Nice 💙 it works with python but how to check only one parameter instead of everything?
            something like this
                    if type == c4d.MSG_DESCRIPTION_USERINTERACTION_END:
                            print "Finished"
            • S Offline
              s_bach
              the message MSG_DESCRIPTION_USERINTERACTION_END has no data. You could store the old value of the parameter in question and check if that value has changed.
