    MSG_UPDATE is sent after pressing button in Material Data
    c++r20
    3 Posts 2 Posters 1.1k Views 1 Watching
    • P Offline
      peterakos
      Hello.
      When I press a button in MaterialData, the message MSG_DESCRIPTION_COMMAND is sent.
      After that I always receive a MSG_UPDATE as well.
      Is there anything I should do to avoid that ?
      After handling the button callback, I return TRUE.
      Thank you.
        Hi @peterakos, MSG_DESCRIPTION_COMMAND is used to trigger the action of pressing the button.
        But in most of the case, if there is a button, it's to do something, so actually modify something which will then probably trigger a MSG_UPDATE.
        Moreover you can test it with a Python Generator and UserData button attached. If you click on the button only MSG_DESCRIPTION_COMMAND is triggered.
        def message(id, data):
            if id == c4d.MSG_DESCRIPTION_COMMAND:
                print "Button Clicked"
            elif id == c4d.MSG_UPDATE:
                print "MSG_UPDATE"
            return c4d.BaseObject(c4d.Ocube)
        May I ask you what are you trying to achieve?
        • P Offline
          peterakos
          Hello.
          Thank you very much for your clarification on this.
          I have a button in MaterialData that saves the material in a specific format in the disk.
          I doesn't change anything in the material but the MSG_UPDATE is sent anyway.
          So, since I don't want to run the MSG_UPDATE handler, I have to set a flag to true in order to skip it.
          Thank you.
