    how to insert a gradiet with step interperation?
    pythonr20
    3 Posts 2 Posters 1.3k Views 1 Watching
      milkliu
      hello!
      i want to insert a gradient with step interperation.
      but this code"grad.SetData(c4d.GRADIENT_INTERPOLATION, c4d.GRADIENT_INTERPOLATION_NONE)"seems don't work.
      i want to know where do i made a mistake?
      this is my code:
      from c4d import gui
          newMat=c4d.BaseMaterial(c4d.Mmaterial)             #create a new material
          newShader=c4d.BaseShader(c4d.Xgradient)            #create a new gradient shader
          newShader[c4d.SLA_GRADIENT_TYPE]=2001              #change type to 2D-v
          grad=newShader[c4d.SLA_GRADIENT_GRADIENT]       #get the gradient gui
          grad.SetData(c4d.GRADIENT_INTERPOLATION, c4d.GRADIENT_INTERPOLATION_NONE) #Change the interpolation
          newShader[c4d.SLA_GRADIENT_GRADIENT]=grad           #reassigned the gradient
          newMat[c4d.MATERIAL_COLOR_SHADER]=newShader         #gradient to color channel
          newMat.InsertShader(newShader)                      #insert shader
          doc.InsertMaterial(newMat)                          #insert material
          newMat.Message(c4d.MSG_UPDATE )
          newMat.Update( True, True )
        Hi, @milkliu, unfortunately, the documentation was not updated to R20 change of the Gradient class.
        But this will be done for the next release.
        With that's said, now as you may have seen, Interpolation are stored per knot and not global to the whole gradient. So after R20 Cinema4D have a GRADIENT_KNOT BaseContainer which holds all knots information.
        Here a full example to use it.
            # Create a new material
            newMat = c4d.BaseMaterial(c4d.Mmaterial)
            # Create a new gradient shader
            newShader = c4d.BaseShader(c4d.Xgradient)
            # Change type to 2D-v
            newShader[c4d.SLA_GRADIENT_TYPE] = c4d.SLA_GRADIENT_TYPE_2D_V
            # Get the Gradient gui
            grad = newShader[c4d.SLA_GRADIENT_GRADIENT]
            # Get the BaseContainer for all Knots
            bcAllKnots = grad.GetData(c4d.GRADIENT_KNOT)
            # Iterate over the knots and define their interpolations to linear
            for k, knotBc in bcAllKnots:
                knotBc[c4d.GRADIENTKNOT_INTERPOLATION] = c4d.GRADIENT_INTERPOLATION_NONE
            # Set the position of the second knot to 0,5
            # We use GetIndexData/SetIndexData because all knot basecontainer get 0 as Id.
            knotBc = bcAllKnots.GetIndexData(1)
            knotBc[c4d.GRADIENTKNOT_POSITION] = 0.5
            bcAllKnots.SetIndexData(1, knotBc)
            # Then we push back our modification to the basecontainer stored in the Gradient Gui
            grad.SetData(c4d.GRADIENT_KNOT, bcAllKnots)
            # Reassigned the gradient
            newShader[c4d.SLA_GRADIENT_GRADIENT] = grad
            # Gradient to color channel
            newMat[c4d.MATERIAL_COLOR_SHADER] = newShader
            # Insert shader into the mat
            # Insert material in the doc
            # Update the document
        If you have any question, please let me know.
          milkliu
          yeah! I got it!
          Thank you very much!
