    Seperators in GetSubContainer
    pythonwindowsr20
    2 Posts 2 Posters 603 Views 1 Watching
    • B Offline
      Boony2000
      Hi again!
      I am still messing around with custom menus. Is it possible to add any kind of seperator inside a submenu?
      Trying to insert a seperator inside GetSubContainer doesn't do anything.
      I am trying to do something like the redshift menu has.
      Or do the seperators here mean that the grouped entries are seperate commandData Plugins?
      A workaround might be to add disabled entries that display a line by naming them "----------&d&"
      Is there documentation on stuff like &d& or [name]&i[iconID]&? Finding these nuggets of wisdom by chance in random forums is not a very efficient way to figure out stuff.
        Hi @Boony2000
        In a GetSubContainer, to insert a separator use InsData(0, "") The ID used should always be 0. As described in ShowPopupDialog Example.
        Which give us
            def GetSubContainer(self, doc, submenu) :
                menuItems = [["name1"], ["name2", "hasIcon"], ["name3"]]
                for i, data in enumerate(menuItems) :
                    if len(data) > 1:
                        submenu.SetString(i+1000, data[0] + "&i" + str(c4d.IDM_KEY_NEXT) + "&")
                        submenu.InsData(0, "")
                        submenu.SetString(i+1000, data[0])
