    INCLUDE user-defined res files
    3 Posts 2 Posters 1.2k Views 1 Watching
    • merkvilsonM Offline
      merkvilson
      Hello PluginCafe 🙂
      I'm creating a set of plugins with many identical description elements.
      I want to create a separate res file and then import its data to another file.
      for example, when I want to include spline properties to my description then I'm using this code
      INCLUDE Ospline;
      Is it possible to use this code for importing my own data which is placed in the same description folder?
        merkvilson
        I'm such an idiot 😂 Seems like the same code can be applied to user-defined descriptions.
        SOLVED! 👌
        • a_blockA Offline
          a_block
          no, you are not! ☺
          Really there are no stupid questions and please do not delete such posts. Especially not, if you already invested time in posting the correct answer. We'd rather see this as knowledge others might benefit from in the future.
          Andreas
