    FILENAME attribute extension filter
    c++
    5 Posts 2 Posters 1.2k Views 1 Watching
    • rsodreR Offline
      rsodre
      hello,
      I have a resource file containing a FILENAME attribute.
      I want it to be able to select only files of a specific extension.
      Usually I configure custom GUI attributes in GetDDescription, but I don't find anything in customgui_filename.h to set the extension.
      Is it possible? How?
      • S Offline
        s_bach
        a FILENAME parameter has no options to set a suffix.
        If you want to only select files of a specific type you could implement SetDParameter() to check if the given Filename is acceptable.
        rsodreR 1 Reply Last reply Reply Quote 3
        • rsodreR Offline
          rsodre @s_bach
          @s_bach Hi Sebastian,
          How exactly can I reject the file selected by the user?
          This is what I tried, I can see the message dialog when the user selects an unexpected file, but the value is always set, independent if I return true, false, or unset the flags.
          Bool AnimationModifier::SetDParameter( GeListNode* node, const DescID& id, const GeData& t_data, DESCFLAGS_SET& flags )
          	auto paramId = id[0].id;
          	if ( paramId == anm_FilePathAttribute )
          		auto suffix = t_data.GetFilename().GetSuffix().ToLower();
          		if ( suffix != "abc"_s )
          			MessageDialog( "Select an Alembic file with extension .abc"_s );
          			//flags &= ~DESCFLAGS_SET_PARAM_SET;
          			//return true;
          			return false;
          	return SUPER::SetDParameter( node, id, t_data, flags );
          • S Offline
            s_bach
            you could try to write an empty value into the BaseContainer when the suffix is wrong. Something like this:
            case EXAMPLE_FILENAME_PARAM:
              const maxon::String suffix = t_data.GetFilename().GetSuffix().ToLower();
              if (suffix != "abc"_s)
                BaseContainer& bc = static_cast<BaseList2D*>(node)->GetDataInstanceRef();
                bc.SetFilename(EXAMPLE_FILENAME_PARAM, Filename());
                flags |= DESCFLAGS_SET::PARAM_SET;
                return true;
            Please notice there is no "official" solution to this; just use what works for you.
            rsodreR 1 Reply Last reply Reply Quote 0
            • rsodreR Offline
              rsodre @s_bach
              @s_bach Ok, I can revert the values to the base container. That solves my issue, thanks!
