    maxon::String in classic API
    6 Posts 3 Posters 1.3k Views 1 Watching
    • C4DSC Offline
      C4DS
      While converting a plugin to R20 I was replacing all String occurrences with maxon::String.
      However, I encountered some issue when compiling.
      Maybe I am just not understanding the conversion process correctly?
      As such, I didn't add tags for "bug report", "issue", "API" ... feel free to add the required once.
      As far as I am aware I am still using the classic API for most of the plugin structure, but am using the MAXON API for the new datastructures.
      maxon::BasseArray::Append, for instance, requires the use of the new error system, etc ...
      According to
      Using new Data Types
      The MAXON API introduces new data types and replaces or extends classic data types:
          The new maxon::String class is the base class of the classic String class. To declare a string literal as a maxon::String one can use the "_s" qualifier. The classic API has been refactured to use maxon::String wherever possible. ...
      From reading the last sentence, I was assuming converting to maxon::String was the way to go.
      However, the SNHookClass (and thus derived classes) still seem to work with the legacy String
      Should I refrain from using maxon::String here and use the legacy String instead?
      • O Offline
        Ogers
        You probably have declared the String as const String& instead of const maxon::String& in the parent class SNHookClass.
        Hope it helped you.
        • C4DSC Offline
          C4DS
          Well, that is what I mean.
          The documentation says the classic API has been refactored, but the SNHookClass apparently isn't.
          • O Offline
            Ogers
            Well I guess that is because the cinema.framework still contains the classic c4d API as mentioned on the Maxon documentation.
            • S Offline
              s_bach
              if you implement a function of a sub-class, the function signature must match the function declaration in the base class. So if the base class is using String, you must use String in your implementation.
              As the documentation says, maxon::String was used wherever possible. Not everywhere.
              • C4DSC Offline
                C4DS
                Thanks for the confirmation SNHookClass still using the legacy String.
