Removing objects from InExclude List and GUI (CommandData Plugin)
Hi everyone,
Trying to find a solution to remove objects from a InExclude List from a CommandData plugin.
inExcludeData = self.linkObjs.GetData() objCount = inExcludeData.GetObjectCount() for i in range(objCount): print inExcludeData.ObjectFromIndex(activeDocument, i) print objCount inExcludeData.DeleteObject(i)I can see that that the count goes down and assume the list is being cleared, but the GUI still shows the objects. How can I update it please?
Apologies if this has been solved before, as I couldn't find the thread or answer.Thank you in advance!
Andre
Hi Andre,
by calling
GetData()you receive a copy of theInExcludeData. By writing the changed data back viaSetData()it should work as expected.I turned this thread into a question.
Andreas -
Amazing! Thank you again Andreas!
