    Removing objects from InExclude List and GUI (CommandData Plugin)
    pythonwindowsr19
    3 Posts 2 Posters 998 Views 2 Watching
    • A Offline
      AndreAnjos
      Hi everyone,
      Trying to find a solution to remove objects from a InExclude List from a CommandData plugin.
      inExcludeData = self.linkObjs.GetData()
      objCount = inExcludeData.GetObjectCount()
      for i in range(objCount):
          print inExcludeData.ObjectFromIndex(activeDocument, i)
          print objCount
          inExcludeData.DeleteObject(i)
      I can see that that the count goes down and assume the list is being cleared, but the GUI still shows the objects. How can I update it please?
      Apologies if this has been solved before, as I couldn't find the thread or answer.
      Thank you in advance! ☺
      Andre
      • a_blockA Offline
        a_block
        Hi Andre,
        by calling GetData() you receive a copy of the InExcludeData. By writing the changed data back via SetData() it should work as expected.
        I turned this thread into a question.
        Andreas
        • A Offline
          AndreAnjos
          Amazing! Thank you again Andreas!
