    How to use c4dpy for Cinema4D R20 SP1
    18 Posts 6 Posters 11.8k Views 4 Watching
    • dskeithbuckD Offline
      dskeithbuck @alfieB
      @alfieb Thanks for the heads up. Added a screenshot to clarify.
      • a_blockA Offline
        a_block
        Thanks Donovan for your elaborate description.
        I'll notify in this thread as soon as the section about c4dpy got added to the Python SDK docs.
        One reminder:
        Please help us to keep this place tidy and make use of the available tags, when posting. For this thread I already added some.
        • G Offline
          GiuseppeLecis
          Hello everyone,
          Someone have tested this workflow on mac? I'm trying to do it on a mac but i can't setup the IDE. Probably the problem is my lack in terminal shell usage but i don't know if possible to execute a .exe file via shell on a mac system. When i drag the c4dpy.app file into the shell and after pressed enter i don't see this "Welcome to the world of C4D and Python 2.7.14 (default, May 3 2018, 18:05:57) [MSC v.1500 64 bit (AMD64)] (c) 2018" but this " -bash: /Applications/MAXON/Cinema 4D R20/c4dpy.app: is a directory". If i drag the c4dpy.exe the result is: -bash: /Applications/MAXON/Cinema 4D R20/c4dpy.exe: cannot execute binary file
          Going on i can't set up the environment properly. Someone could help me please? thanks in advance
          G.L.
          • A Offline
            alfieB
            Hi Giuseppe,
            After the instruction from dskeithbuck, i set up on both windows and mac. With mac its a little different due the way the os packages things. You are getting the error message because the .app is indeed a directory. Open it by right click -> Show package contents -> Contents -> MacOS and in there is the executable you need.
            Hope this helps.
            Alfie
            G 1 Reply Last reply Reply Quote 1
            • G Offline
              GiuseppeLecis @alfieB
              @alfieb Thank you so much for your kindly reply! I have solved thanks to your suggestion :-)!
              • a_blockA Offline
                a_block
                we have updated the Python SDK documentation including c4dpy instructions.
                Let us know, if you are missing something in there.
                Andreas
                • T Offline
                  tychris
                  I haven't been able to get c4dpy.exe to run without throwing an 0xC5 access violation error. I have the latest .exe downloaded and placed next to all the other C4D R20 executables, and my R20 instance is running R20.028. Does c4dpy.exe need to be updated for R20.028? I see lots of "UNKNOWNBUILDID" messages in stdout.
                  • a_blockA Offline
                    a_block
                    I'm terribly sorry for the inconvenience caused. You are right c4dpy needs to be updated for the latest hotfix (Cinema 4D R20 SP1, 20.028). Unfortunately due to our travels I had failed to upload the file. Sorry!
                    The updated version is now available on our blog's download page[URL-REMOVED].
                    Bye,
                    Andreas
                    mikeudinM 1 Reply Last reply Reply Quote 0
                    • T Offline
                      tychris
                      Cool! Thanks very much. That's working for me now.
                      • mikeudinM Offline
                        mikeudin @a_block
                        @a_block could you update the link to latest version of c4dpy here?
                        https://developers.maxon.net/docs/py/2023_2/misc/c4dpy.html
                        https://mikeudin.net
                        • a_blockA Offline
                          a_block
                          @mikeudin Thanks for making us aware. We'll change the link with the next docs update.
