    Quaternion rotation
    5 Posts 3 Posters 2.4k Views 2 Watching
    • T Offline
      Tudor
      Hello friends,
      I'm trying to work with the Quaternion-Object.
      My cam-Object should align to the direction vector and pointed in this case in X-Direction.
      But if print the q.v value I get a zero vector and the rotation is not applied
      Does I misunderstood the Quaternion-Syntax? I can't find nothing about that.
      cam = op.GetObject()
          direction = c4d.Vector(10,0,0).GetNormalized()
          angle = 0
          q = c4d.Quaternion()
          q.SetAxis(direction, angle)
          b = q.GetMatrix()
          b.off = cam.GetAbsPos()
          cam.SetMg(b)
          print q.v
      • r_giganteR Offline
        r_gigante
        Hi Tudor,
        actually your code is properly behaving, since the angle is set to 0. If, by chance, you set it to PI/2 you will immediately see that the camera promptly rotates and point up to the sky.
        Hope the screenshot clarifies the situation
        Best, Riccardo
        • T Offline
          Tudor
          I thought I can use this direction vector as Quaternion-Axis. The cam should point than to the target.
          But but it seems i need a different approach.
          import c4d, math
          target = op[c4d.ID_USERDATA,1]
             tarPos = target.GetAbsPos()
             camPos = cam.GetAbsPos()
             direction = (tarPos - camPos).GetNormalized()
             angle = math.pi/2  #?
             b = q.GetMatrix()
             cam.SetMg(b)
            r_gigante
            Hi Tudor, that's indeed not the way to proceed.
            Quaternion is just a tool to conveniently represent a rotation in the space. That said the approach you need to follow is just to rotate the camera until it points where your target is.
            Cheers, Riccardo
            • a_blockA Offline
              a_block
              please, do not delete discussions threads. The contained information might be valuable for future readers.
              Andreas
