    n-gones with python
    3 Posts 2 Posters 1.2k Views 2 Watching
    • Passion3DP Offline
      Passion3D
      I found that the c ++ sdk had a routine for creating n-gones, but I did not find anything in python. By importing a wavefront that contains n-gones with my plugin, the import is not done properly. Is there a python solution or should I convert my plugin to c ++?
      • eZioPanE Offline
        eZioPan
        hi @passion3d,
        There is no actual n-gon in the underlying layer of Cinema 4D.
        Adjacent polygons use hidden edge to create n-gon-like shape(s).
        Following code creates a 5-side polygon object:
        import c4d, math
        from c4d import utils
            pointCount = 5
            polygonCount = math.ceil(pointCount/4.0)                    # caculate minimum needed polygon number
            polyObj = c4d.BaseObject(c4d.Opolygon)                      # create an empty polygon object
            polyObj.ResizeObject(pcnt=pointCount, vcnt=polygonCount)    # resize object to have 5 points, 2 polygons
            # manually set all point position
            polyObj.SetPoint(id=0, pos=c4d.Vector(200,0,-200))
            polyObj.SetPoint(id=1, pos=c4d.Vector(-200,0,-200))
            polyObj.SetPoint(id=2, pos=c4d.Vector(-200,0,200))
            polyObj.SetPoint(id=3, pos=c4d.Vector(200,0,200))
            polyObj.SetPoint(id=4, pos=c4d.Vector(300,0,0))
            # associate points into polygons
            polygon0 = c4d.CPolygon(t_a=0, t_b=1, t_c=2, t_d=3)
            polygon1 = c4d.CPolygon(t_a=0, t_b=3, t_c=4)
            # set polygon in polygon object
            polyObj.SetPolygon(id=0, polygon=polygon0)
            polyObj.SetPolygon(id=1, polygon=polygon1)
            # set hidden edge
            nbr = utils.Neighbor()
            nbr.Init(op=polyObj, bs=None)                               # create Neighor counting all polygon in
            edge = c4d.BaseSelect()
            edge.Select(num=3)                                          # set selection, which is the id of the edge to be hidden
            polyObj.SetSelectedEdges(e=nbr, pSel=edge, ltype=c4d.EDGESELECTIONTYPE_HIDDEN)  # hide the edge
            polyObj.Message(c4d.MSG_UPDATE)
            doc.InsertObject(polyObj)
          Passion3D
          Hi @eZioPan
          thank you for this example very clear šŸ˜‰
