    Which message do I receive when a command plugin dialog is closed?
    pythonr19
    4 Posts 3 Posters 1.6k Views
    • P Offline
      pim
      I have a command plugin with a dialog.
      Which message do I receive when I close this dialog?
      This is how I checked for a close dialog.
      class MyDialog(gui.GeDialog):
          def Message(self, msg, result):
              id = msg.GetId()
              #print "id: ", id
              if (id == c4d.C4DPL_END):
                 print "Plugin closed."
              return gui.GeDialog.Message(self, msg, result)
        mp5gosu
        You can simply implement AskClose(): https://developers.maxon.net/docs/py/2023_2/modules/c4d.gui/GeDialog/index.html?highlight=askclose#GeDialog.AskClose
        Or even DestroyWindow() etc.
        • S Offline
          s_bach
          as @mp5gosu has pointed out you can implement AskClose() and DestroyWindow() to be informed on these events.
          You find an example for AskClose() in Py-TextureBaker.pyp.
          You also find general information on GeDialog in the C++ documentation:
          • GeDialog Based Classes
          • P Offline
            pim
            @s_bach said in Which message do I receive when a command plugin dialog is closed?:
            DestroyWindow
            Thanks.
            By the way, compliments on the latest R20 C++ manual. It is great!
