    SetPercent() not working...
    r19
    7 Posts 3 Posters 2.1k Views 2 Watching
    • G Offline
      gogeta
      I am using ProgressDialog() class to show the progress bar in my plugin. I got the example from here.
      This example works fine and shows a good progress bar but when I customized it to use for my code it stopped showing the progress percentage which was set using SetPercent().
      Here is my code :
      void ProgressBarDialog::Timer(const BaseContainer &msg)
      	GePrint("ProgressBarDialog::Timer() is called.");
      	GePrint("value of percentIncrease = " + String::FloatToString((percentIncrease)));
      	percentIncrease += 2.0f;
      	SetPercent(percentIncrease/100);
      Also if I am using the SetPercent() in *void ProgressBarDialog::Main(C4DThread bt) function of ProgressDialog(), it is still not working.
      Please help me with this as I am stuck with it for a long time.
      Thanks In Advance.
        mp5gosu
        @gogeta said in SetPercent() not working...:
        percentIncrease/100
        This results in being an Int. Because you divide a float by 100 and that results in an Int rounded to 0.
        So simply cast it to float - right as the example you linked, does.
        • G Offline
          gogeta
          I tried the same as suggested by you but it still didn't work ☹ .
          I even tried with hardcoded float values but still no progress.
          I am not able to understand why is this happening 😅 .
          Update: In Main() function of ProgressDialog class I am doing some task and also updating the progress bar with SetPercent(0.1F), SetPercent(0.2F) and so on.
          Please guide me.
          Thanks.
            mp5gosu
            Would you mind to share the relevant portion of your code?
            G 1 Reply Last reply Reply Quote 1
            • G Offline
              gogeta @mp5gosu
              @mp5gosu Hi,
              I can't provide you the exact code but I am providing some portion of code for understanding. Please have a look into this.
              Bool ProgressBarDialog::CreateLayout()
              	return ProgressDialog::CreateLayout();
              Bool ProgressBarDialog::InitValues()
              	GePrint("Initializing progress bar values.");
              	//percentIncrease = 0.0F;
              	//this->SetTimer(1000);
              	return ProgressDialog::InitValues();
              void ProgressBarDialog::Main(C4DThread *bt)
              	GePrint("In Main function.");
              	Bool status = false;
              	/*some variables*/
              	String str1;
              	String str2;
              	/*Set progress bar 10%*/
              	SetPercent(0.1f);
              	DWORD flag = doSomework();
              	status = readStatus(arg1,arg2,arg3);
              	if (!status)
              		MessageDialog("Please Try Again. Facing Issue !");
              		isErrorOccurred = true;
              		return ;
              	/*Set progress bar 20%*/
              	SetPercent(0.2f);
              	//StatusSetBar(10);
              	/*some relevant tasks*/
              	/*Set progress bar 30%*/
              	SetPercent(0.3f);
              	status = doSomeCommunication(buff1, buff2);
              	/*Set progress bar 60%*/
              	SetPercent(0.6f);
              	if (!status)
              		/*Set progress bar 70%*/
              		SetPercent(0.7f);
              		/*Perform other tasks*/
              		/*Set progress bar 80%*/
              		SetPercent(0.8f);
              	else
              		SetPercent(0.7f);
              		status = doSomeParsing(Buff1, &var1);
              		if (!status)
              			MessageDialog(buff[0]); //display error msg
              			return ;
              		/*Set progress bar 90%*/
              		SetPercent(0.9f);
              		/*do some other tasks*/
              	/*Set progress bar 100%*/
              	SetPercent(1.f);
              	SetPercent((Float)percentIncrease / 100);
              Thanks!
                Hi @gogeta sorry for the late reply.
                Since ProgressDialog makes use of a Timer in order to refresh the UI, you must call the Super::Timer operator like so at the end of your Timer function.
                return ProgressDialog::Timer(msg);
                If you have any questions please let me know!
                G 1 Reply Last reply Reply Quote 2
                • G Offline
                  gogeta @m_adam
                  @m_adam Hi,
                  Thanks for your answer. I applied your changes and it worked like a charm ☺ .
                  Thanks again!!!
