    Description... missing member "ID"
    5 Posts 3 Posters 1.7k Views 1 Watching
    • E Offline
      ello
      while updating to r20 i get a lot of errors according to DescriptionCommad / DescriptionGetBitmap, ID is no member
      	case MSG_DESCRIPTION_COMMAND:
      		switch(static_cast<DescriptionCommand*>(t_data)->id[0].id)
      	case MSG_DESCRIPTION_GETBITMAP:
      		DescriptionGetBitmap *dgb = static_cast<DescriptionGetBitmap*>(t_data);
      		AutoAlloc<BaseBitmap> bm;
      		switch(dgb->id[0].id)
      edit: maybe i found something . _descId[0].id doesn't throw an error. however i still cannot test way more errors and warnings to go 😉
      • rsodreR Offline
        rsodre
        In R20, it changed to id[0]._descId
        E 1 Reply Last reply Reply Quote 1
        • E Offline
          ello @rsodre
          @rsodre so it is wrong way? my code seems to compile now
          • S Offline
            s_bach
            in Cinema 4D R20 the id member was removed from several structures like DescriptionCommand or DescriptionPopup. These structures now share a common base class: DescriptionBaseMessage. See API Change List in R20.
            DescriptionBaseMessage has the member _descId which can be used instead.
            Is your issue solved with that information?
            E 1 Reply Last reply Reply Quote 2
            • E Offline
              ello @s_bach
              @s_bach thank you. i still am on my road... at least it solves the compiler error. i get quite some crashes after updating. guess this will take some time
