    Modify Spline Gui
    3 Posts 2 Posters 1.4k Views 1 Watching
      HolgerBiebrach
      Hi, is there a way to modify the shape of a Spline in the Spline Gui? For example I want to edit the Curve in the Splinedeformer Shape Parameter. The Log only spits out c4d.SPLINEDEFORMEROBJECT_SPLINECONTROL
      How can I modify the cooridates of the spline points?
      • S Offline
        s_bach
        the parameter c4d.SPLINEDEFORMEROBJECT_SPLINECONTROL contains a c4d.SplineData object. You can edit this object to edit the spline.
        Please notice that the Spline Deformer adapts the spline range based on the "Radius" parameter.
        With that in mind you can easily access and edit the points defining that spline:
        # get spline data
        splineData = op[c4d.SPLINEDEFORMEROBJECT_SPLINECONTROL]
        # print information on the data
        print(splineData)
        # radius is max. value
        radius = op[c4d.SPLINEDEFORMEROBJECT_RADIUS]
        # delete all points
        splineData.DeleteAllPoints()
        splineData.SetRange(0.0, radius, 0.1, 0.0, 1.0, 0.1)
        # insert knots
        splineData.InsertKnot(0.0, 0.0)
        splineData.InsertKnot(radius, 1.0)
        # modify knots
        splineData.SetKnot(0,c4d.Vector(0.0,0.0,0), 0, False, c4d.Vector(0,0,0), c4d.Vector(1,1,0),c4d.CustomSplineKnotInterpolationBezier)
        splineData.SetKnot(1,c4d.Vector(radius,1.0,0), 0, False, c4d.Vector(-1,-1,0), c4d.Vector(0,0,0),c4d.CustomSplineKnotInterpolationBezier)
        # store back to deformer object
        op.SetParameter(c4d.SPLINEDEFORMEROBJECT_SPLINECONTROL, splineData, c4d.DESCFLAGS_SET_0)
        • S Offline
          s_bach
          Hello @HolgerBiebrach ,
          I'm wondering if your question has been answered. If so, please mark this thread as solved.
