    Check if Object is Spline Type
    3 Posts 2 Posters 1.6k Views 1 Watching
      HolgerBiebrach
      Hello, I need to check if an Object is a Spline. By that I mean not only a SplineObject but also any kind of Spline Generator like TextSpline, Mospline, Circlespline etc.
      With this Code I usually Check if a Object is a Generator or Deformer (Modifier). But I did not find a way for checking for Splines.
      obj_info = obj.GetInfo()
          is_generator = obj_info & c4d.OBJECT_GENERATOR
        Hi @HolgerBiebrach, welcome back in this forum.
        First of all, I would like to point you, to our Q&A functionnality in order to use as best as we can the new features offered by the forum.
        I let you set up your first post as a question.
        Moreover please use the 3 single quote markdown in order to make code block ```your code```.
        With that's said, regarding your question you can simply check for c4d.OBJECT_ISSPLINE like so bool(op.GetInfo() & c4d.OBJECT_ISSPLINE).
        If you have any questions please let me know.
        Maxime!
          HolgerBiebrach
          Hi Maxime. Thanks a lot. That helped me.
