    Force InExclusionData update after remove object outside of In-/Exclusion User Data
    pythonr19
    7 Posts 2 Posters 2.6k Views 2 Watching
    • eZioPanE Offline
      eZioPan
      I have a very simple scene:
      • A Null Object with an In-/Exclusion User Data
      • A Python Tag on the Null Object
      • some script in the Python Tag
          obj = op.GetObject()
          objList = obj[c4d.ID_USERDATA,1] # point to the In-/Exclusion User Data
          print(objList.GetObjectCount())
      If I add scene objects into In-/Exclusion User Data, or remove object within In-/Exclusion User Data, Python Tag will print correct object count.
      But if I remove an object from the Object Manager which had been added into the In-/Exclusion User Data before, I can see object has been removed in In-/Exclusion User Data, but Python Tag report wrong object count (as if the object has not been removed).
      And only if I make some change within the In-/Exclusion User Data directly, that the Python Tag report correct count number again.
      I wonder if there is something I'm missing from the script for forcing InExclusionData update, or it's a bug in the "updating system"?
      Thanks!
      • Y Offline
        y_puech
        The InExcludeData object count does not always reflect the accurate number of valid objects depending on the scenarios.
        Additionally to calling GetObjectCount() the returned value from ObjectFromIndex() should be checked if it's not None.
        Former MAXON SDK Engineer
        • eZioPanE Offline
          eZioPan
          Hi, y_puech!
          Thank you for replying!
          I use
          i = 0
          while True:
              obj = InExData.ObjectFromIndex(doc,i)
              if obj == None:
                  break
          i += 1
          to get right result.
          • Y Offline
            y_puech
            Just a quick note on your code. A pythonic solution could be:
            count = inExData.GetObjectCount()
            for i in xrange(count):
                obj = inExData.ObjectFromIndex(doc, i)
                if obj is None:
                    continue
            Why are you breaking out from the loop with the first invalid object in the InExcludeData?
            • eZioPanE Offline
              eZioPan
              Oh! Sorry! I know what you mean in the previous post now. I'm doing the wrong way. Your solution is correct!
              By the way, I wonder if there is a situation where the actual object counts are greater than GetObjectCount() returned?
              Y 1 Reply Last reply Reply Quote 0
              • Y Offline
                y_puech @eZioPan
                This should never happen.
                Thanks for marking the topic as solved. Note that you can mark a specific post as the correct answer or solution. See step 5 in Q&A New Functionality.
                eZioPanE 1 Reply Last reply Reply Quote 2
                • eZioPanE Offline
                  eZioPan @y_puech
                  Hi, @y_puech I may find a bug of the forum about "mark a post correct answer", discussion post here: Cannot mark post as answer
                  Once this bug solved, I will re-edit this topic and posts correctly.
