    Controlling Shader with Userdata
    5 Posts 3 Posters 1.8k Views
    • B Offline
      bencaires
      Hey,
      I'm trying to control a shader from some userdata but I keep getting this error:
      Traceback (most recent call last):
      File "'Python'", line 6, in main
      AttributeError: parameter access failed
      I'm not sure what I'm missing here.
      https://www.dropbox.com/s/0pvpjbiiofqdwg5/LinkShader_Py.c4d?dl=0
          ShaderOb = op[c4d.ID_USERDATA,3]
          ShaderOp = op[c4d.ID_USERDATA,c4d.ID_MG_SHADER_SHADER]
          ChannOp = op[c4d.ID_USERDATA,c4d.ID_MG_SHADER_CHANNELSELECT]
          ShaderOb[c4d.ID_MG_SHADER_SHADER] = op[c4d.ID_USERDATA,c4d.ID_MG_SHADER_SHADER]
          ShaderOb[c4d.ID_MG_SHADER_CHANNELSELECT] = op[c4d.ID_USERDATA,c4d.ID_MG_SHADER_CHANNELSELECT]
        Hi Bencaires,
        I can confirm there is a bug in C4D when you drag and drop a user data parameter into the console from your scene, the wrong ID is written.
        With that's said if you open the User Data Manager (In the description of an object, in the top menu, User Data => Manage User Data ...). Select your User Data parameter then below the name/short name you get the actual ID of this parameter.
        So in your case, if you write the correct ID, your script is working nicely.
        	ShaderOb = op[c4d.ID_USERDATA, 3]
        	ShaderOp = op[c4d.ID_USERDATA, 10]
        	ChannOp = op[c4d.ID_USERDATA, 2]
        	ShaderOb[c4d.ID_MG_SHADER_SHADER] = op[c4d.ID_USERDATA, 10]
        	ShaderOb[c4d.ID_MG_SHADER_CHANNELSELECT] = op[c4d.ID_USERDATA, 2]
        • B Offline
          bencaires
          Thank you m_adam that works perfectly now. Is that bug in all versions of cinema?
            Yes, the issue comes from the fact you have created user data by Copying User Data interface from the shader interface (nothing wrong here).
            But when you copy and paste user data Interface due to a bug, the previous ID is kept and used when drag and dropping this parameter.
            dskeithbuckD 1 Reply Last reply Reply Quote 0
            • dskeithbuckD Offline
              dskeithbuck @m_adam
              @m_adam I've run into the copy/paste UserData bug a few times. Glad it's been reported!
