    About threads
    c++r20
    4 Posts 2 Posters 1.7k Views
    • A Offline
      anoano
      Hello
      The around thread becomes new from R20 and it does not work with the old code.
      I am trying while looking at the SDK sample, but it does not move with an error.
      No 1 error
      An operator that handles the right operand of maxon :: ResultMemT <maxon :: BaseRef <IMPLEMENTATION, maxon :: StrongRefHandler >> 'can not be found (or can not be converted).
      class MyThread : public maxon::ThreadInterfaceTemplate<MyThread>
      const char* GetName() const { return "MyThread"; }
      maxon::Result<void> operator ()()
      GePrint("ok"_s);
      class MenuTest : public CommandData
      static maxon::ThreadRefTemplate<MyThread> g_test;
      virtual Bool Execute(BaseDocument
      doc);
      Bool MenuTest::Execute(BaseDocument doc)
      if (!g_test) g_test = MyThread::Create() iferr_return; // No1 Error
      Please tell me if you can understand.
      • S Offline
        s_bach
        there are a few issues with the code you posted.
        First, please make sure to use the correct function declarations. CommandData::Execute() is defined as
        Execute(BaseDocument* doc)
        The doc argument is a pointer, not a copy.
        Second, please pay attention to return values. The Execute() function must return a Bool value. The operator()() of the thread must return a maxon::Result<void>.
        In the Execute() function you create a thread instance. You must handle the error object returned by the Create() function.
        There are multiple ways to handle such error values. You find examples in the Error Handling manual.
        One way would be to use iferr_scope_handler. With that the Execute() function can look like this:
        Bool MenuTest::Execute(BaseDocument* doc)
          iferr_scope_handler
            err.DiagOutput();
            err.DbgStop();
            return true;
          if (!g_test)
          return true;
        The worker function (operator()()) of the thread must return a Result<void> object. This is typically maxon::OK when everything is OK. You find an example of such a custom thread in the Threads Manual.
        Some more hints:
        • for new code please use ApplicationOutput() instead of GePrint(). See API Transition.
        • when posting code please use the Markdown syntax. See also Markdown summary.
        • A Offline
          anoano
          Hi.
          Thank you for teaching me.
          I am not sure of the new maxon API Threading.
          Are there samples of jobs and Threads?
          • S Offline
            s_bach
            you find information and examples on jobs and threads in these manuals:
            • Jobs Manual
            • Threads Manual
