    Viseme RIG test
    6 Posts 3 Posters 2.8k Views 1 Watching
    • G Offline
      Gal
      in order to faster the mouth animation process of a character,
      i try to create a viseme rig.
      I have put on an object a pose morph tag with 6 sliders for 6 visemes.
      I created a dynamic text in user data, to edit viseme orders .
      I created an Xpresso tag, with python node, to control visemes sliders.
      It works, but in a boolean way !
      I want to improve this Xpresso and python Rig to control sliders
      in a linear way (from 0% to 100%, or 100% to 0%) !
      With duration for the moving sliders between viseme orders
      With conditions for the position of the sliders (e.g.: if slider 1 at position 0, go to 100, if slider 2 at position 100, go to 0 ....).
      How can i do it ?
      I'm a python rookie !
      Thank's
      • r_giganteR Offline
        r_gigante
        Hi Gal, thanks for writing us.
        With regard to the issue reported, it looks to me like some sorting of unwanted data-clamping effect due to type casting. To be more helpful please provide your code snippet ( or a complete test asset) in order to dig further.
        Best, Riccardo
        • G Offline
          Gal
          @r_gigante said in Viseme RIG test:
          Hi Ricardo,
          Thank you for your answer.
          I've a little bit improved my xpresso nodes, simple but efficient !
          The viseme are controlled in a boolean way = step key frame.
          With controlling the global intensity of the pose morph tag,
          i can have more interpolation of the lips movement between the viseme step keys frames.
          Mouth rig test_animatic
          How to improved python code in order to have viseme linear key frames ?
          Best regards
          Gal
          This is my simple python code :
              global Output1, Output2, Output3, Output4,  Output5,  Output6,  Output7,  Output8,  Output9,  Output10,  Output11
              if Input1 == "":
                  Output1 = 0
                  Output2 = 0
                  Output3 = 0
                  Output4 = 0
                  Output5 = 0
                  Output6 = 0
                  Output7 = 0
                  Output8 = 0
                  Output9 = 0
                  Output10 = 0
                  Output11 = 0
              if Input1 == "E":
                  Output1 = 1
                  Output2 = 0
                  Output3 = 0
                  Output4 = 0
                  Output5 = 0
                  Output6 = 0
                  Output7 = 0
                  Output8 = 0
                  Output9 = 0
                  Output10 = 0
                  Output11 = 0
              if Input1 == "A":
                  Output1 = 0.8
                  Output2 = 0
                  Output3 = 0
                  Output4 = 0.8
                  Output5 = 0
                  Output6 = 0
                  Output7 = 0
                  Output8 = 0
                  Output9 = 0
                  Output10 = 0.5
                  Output11 = 0.5
              if Input1 == "I":
                  Output1 = 0
                  Output2 = 0
                  Output3 = 0
                  Output4 = 1
                  Output5 = 0
                  Output6 = 1
                  Output7 = 1
                  Output8 = 0
                  Output9 = 0
                  Output10 = 0.5
                  Output11 = 0.5
              if Input1 == "U":
                  Output1 = 0.8
                  Output2 = 0
                  Output3 = 0
                  Output4 = 0
                  Output5 = 0
                  Output6 = 0
                  Output7 = 0
                  Output8 = 1
                  Output9 = 1
                  Output10 = 0
                  Output11 = 0
              if Input1 == "R":
                  Output1 = 0.5
                  Output2 = 0
                  Output3 = 0
                  Output4 = 1
                  Output5 = 0
                  Output6 = -0.5
                  Output7 = -0.5
                  Output8 = 1
                  Output9 = 1
                  Output10 = 0.5
                  Output11 = 0.5
              if Input1 == "O":
                  Output1 = 0.9
                  Output2 = 0
                  Output3 = 0
                  Output4 = 0
                  Output5 = 0
                  Output6 = 0
                  Output7 = 0
                  Output8 = 0.4
                  Output9 = 0.4
                  Output10 = -0.3
                  Output11 = -0.3
              if Input1 == "CH":
                  Output1 = 0.2
                  Output2 = 0
                  Output3 = 0
                  Output4 = 0.35
                  Output5 = 0
                  Output6 = 0.5
                  Output7 = 0.5
                  Output8 = 0
                  Output9 = 0
                  Output10 = 0.6
                  Output11 = 0.6
              if Input1 == "S":
                  Output1 = 0.1
                  Output2 = 0
                  Output3 = 0
                  Output4 = 0.41
                  Output5 = 0.2
                  Output6 = 1
                  Output7 = 1
                  Output8 = 1
                  Output9 = 1
                  Output10 = 1
                  Output11 = 1
              if Input1 == "M":
                  Output1 = 0
                  Output2 = 0
                  Output3 = 0
                  Output4 = 0.1
                  Output5 = 0.3
                  Output6 = 0.6
                  Output7 = 0.6
                  Output8 = 0.85
                  Output9 = 0.85
                  Output10 = 0.4
                  Output11 = 0.4
              if Input1 == "D":
                  Output1 = 0.05
                  Output2 = 0
                  Output3 = 0
                  Output4 = 0.3
                  Output5 = 0.2
                  Output6 = 0.8
                  Output7 = 0.8
                  Output8 = 0.85
                  Output9 = 0.85
                  Output10 = 0.2
                  Output11 = 0.2
              if Input1 == "F":
                  Output1 = 0.05
                  Output2 = 0
                  Output3 = 0
                  Output4 = 0
                  Output5 = 0.2
                  Output6 = 0.8
                  Output7 = 0.8
                  Output8 = 0.5
                  Output9 = 0.5
                  Output10 = 0
                  Output11 = 0
              if Input1 == "L":
                  Output1 = 0.6
                  Output2 = 1
                  Output3 = 0
                  Output4 = 0.2
                  Output5 = 0
                  Output6 = 0.8
                  Output7 = 0.8
                  Output8 = 0.5
                  Output9 = 0.5
                  Output10 = 0
                  Output11 = 0
            r_gigante
            Hi Gal, thanks for following-up.
            With regard to your setup, without changing too much things, you could simply consider to add an additional float parameter to your VISEME data - in order to have three input params "neutral", "VISEME" and a "weight" - and use its value defined by a curve in your python script (below to keep your naming scheme is called Input2) in order to change the weight of your VISEME rig.
                # Input2 is the float parameter defined to weight the viseme
                Output1 = 0
                Output2 = 0
                Output3 = 0
                Output4 = 0
                Output5 = 0
                Output6 = 0
                Output7 = 0
                Output8 = 0
                Output9 = 0
                Output10 = 0
                Output11 = 0
                if Input1 == "E":
                    Output1 = 1.0 * Input2
                elif Input1 == "A":
                    Output1 = 0.8 * Input2
                    Output4 = 0.8 * Input2
                    Output10 = 0.5 * Input2
                    Output11 = 0.5 * Input2
                elif Input1 == "I":
                    Output4 = 1.0 * Input2
                    Output6 = 1.0 * Input2
                    Output7 = 1.0 * Input2
                elif Input1 == "U":
                    Output8 = 1.0 * Input2
                    Output9 = 1.0 * Input2
                elif Input1 == "R":
                    Output1 = 0.5 * Input2
                    Output6 = -0.5 * Input2
                    Output7 = -0.5 * Input2
                elif Input1 == "O":
                    Output1 = 0.9 * Input2
                    Output8 = 0.4 * Input2
                    Output9 = 0.4 * Input2
                    Output10 = -0.3 * Input2
                    Output11 = -0.3 * Input2
                elif Input1 == "CH":
                    Output1 = 0.2 * Input2
                    Output4 = 0.35 * Input2
                    Output6 = 0.5 * Input2
                    Output7 = 0.5 * Input2
                    Output10 = 0.6 * Input2
                    Output11 = 0.6 * Input2
                elif Input1 == "S":
                    Output1 = 0.1 * Input2
                    Output4 = 0.41 * Input2
                    Output5 = 0.2 * Input2
                    Output10 = 1.0 * Input2
                    Output11 = 1.0 * Input2
                elif Input1 == "M":
                    Output4 = 0.1 * Input2
                    Output5 = 0.3 * Input2
                    Output6 = 0.6 * Input2
                    Output7 = 0.6 * Input2
                    Output8 = 0.85 * Input2
                    Output9 = 0.85 * Input2
                    Output10 = 0.4 * Input2
                    Output11 = 0.4 * Input2
                elif Input1 == "D":
                    Output1 = 0.05 * Input2
                    Output4 = 0.3 * Input2
                    Output6 = 0.8 * Input2
                    Output7 = 0.8 * Input2
                    Output10 = 0.2 * Input2
                    Output11 = 0.2 * Input2
                elif Input1 == "F":
                    Output8 = 0.5 * Input2
                    Output9 = 0.5 * Input2
                elif Input1 == "L":
                    Output1 = 0.6 * Input2
                    Output2 = 1.0 * Input2
                    Output4 = 0.2 * Input2
            Hoping it make sense, feel free to get back for any further help.
            Cheer, Riccardo
            • G Offline
              Gal
              Hello
              Thank you Ricardo for the code and this option.
              It works for me !
              Is there a way to control an interpolation of data (e.g. 0 to 100) on a duration (e.g. 10 frames) with python, with only one order keyframe ?
              If you have an advice or a weblink to better learn python for C4D, i'll take it !
              Gal
              • Leo_SaramagoL Offline
                Leo_Saramago
                Hi! You could go for CTracks via Python. You'd have to get the track for a position parameter, for example, or create one, then get curve, then add keys. Later, you could simply range map it back to your Xpresso rig. it It's definitely doable!
                "The idea dictates everything."
                by David Lynch
