    Syntax Highligting in Markdown Code Blocks?
    General Talk
    2.0k
    • dskeithbuckD
      dskeithbuck
      Is it possible to get language-specific syntax highlighting in the markdown code blocks? Something like what GitHub does? If not, what's the best way to submit suggestions for the forum?
      Donovan
      • r_giganteR
        r_gigante
        Hi Donovan, thanks for providing the feedback and I confirm we're working on it.
        I'll notify through post as soon as it will be available.
        Cheers, Riccardo
        • dskeithbuckD
          dskeithbuck
          Great news, thanks!
          • r_giganteR
            r_gigante
            Hi Donovan,
                the syntax highlighting should work now.
            void ThisIsATest()
               // comment it out!
               cout << "This is an highlighted world!";
            Cheers, Riccardo
            • dskeithbuckD
              dskeithbuck
              Awesome! It works with
              python:
              print "Thank you!"
              and C++:
              cout << "For adding syntax highlighting!";
              • r_giganteR
                r_gigante
                For everybody interested in syntax highlighting, nodeBB is pretty smart in recognizing the language you're using by simply checking your code snippet, but in case you really want to hard-code the language set simply use the following line when starting a code snippet:
                ```<language>
                where <language> can be anything like python or c++
                Cheers, Riccardo
                • ferdinandF ferdinand moved this topic from News & Information on
