    [SOLVED] Dynamic Dropdown List
    4 Posts 0 Posters 1.3k Views
      On 09/07/2018 at 21:02, xxxxxxxx wrote:
      Cinema 4D Version:   R18
      Hi all,
      I want to have a drop down list that I can change on the fly with user data. The list is a list of image extensions and I would like to allow users to put in there own custom extensions and then add this to this list.
      The user clicks on custom, enters a custom extension and this is saved to a user configuration file (I have everything up to this point working fine). Where I'm stuck is how I can populate this list with the saved data so that the user can see their custom extensions each time they open a file.
      You can see the code if that makes anything clearer on my GitHub page for the project, the files of interest here are SMDLoader.cpp/.h and fsmdloader.res
      https://github.com/xNWP/Cinema-4D-Source-Tools
      Thank you in advanced to anyone who can help point me in the right direction !!
        On 09/07/2018 at 22:33, xxxxxxxx wrote:
        Here's what I did to fill a dropdown box with filenames and a custom entry
        Bool DisplayMode::GetDDescription(GeListNode* node, Description* description, DESCFLAGS_DESC& flags)
          if (!description->LoadDescription(DISPLAYMODE_DESC_PLUGIN_ID))
              return false;
            // === CHECKER ===
          // fill the dropdown with all available checker types
          const DescID *singleid = description->GetSingleDescID();
          DescID cid = DescLevel(CHECKER_TYPE, DTYPE_LONG, 0);
          if (!singleid || cid.IsPartOf(*singleid, nullptr)) // important to check for speedup c4d!
              SortedStringArray checkerFilenames;
              // read the available checker bitmap filenames
              // add a fixed "Custom Checker" entry in the list,
              // separated from the file entries
              // (leave out separator when no file entries)
              BaseContainer listBC;
              listBC.SetString(CUSTOM_CHECKER_ID, "Custom Checker");
              if (checkerFilenames.GetCount() > 0)
                  listBC.SetString(-1, ""); // separator
              for (SortedStringArray::ConstIterator it = checkerFilenames.Begin(); it != checkerFilenames.End(); ++it)
                  listBC.SetString(Int32(it - checkerFilenames.Begin()), *it);
              // add the items to the dropdown gadget
              BaseContainer comboBC = GetCustomDataTypeDefault(DTYPE_LONG);
                // re-use the original label from the description
                  BaseContainer* bc = description->GetParameterI(cid, nullptr);
                  comboBC.SetString(DESC_SHORT_NAME, bc->GetString(DESC_SHORT_NAME));
              comboBC.SetInt32(DESC_ANIMATE, DESC_ANIMATE_OFF);
              comboBC.SetContainer(DESC_CYCLE, listBC);
                // store the data into the description
              if (!description->SetParameter(cid, comboBC, DescLevel(0)))
                  return FALSE;
          On 10/07/2018 at 01:32, xxxxxxxx wrote:
          as C4DS showed, you can edit the parameter description of a NodeData based element by implementing GetDDescription(). There are multiple manuals and example available:
          • NodeData::GetDDescription() Manual
          • Description Manual
          • Description Settings Manual
          An example of editing a drop down list is found in sculptdeformer.cpp.
            On 10/07/2018 at 15:52, xxxxxxxx wrote:
            Thank-You both!
            This has absolutely done the trick and is working flawlessly 🙂
