    Custom number of parameters for ObjectData plugin
    3 Posts 0 Posters 630 Views
      On 16/11/2017 at 09:53, xxxxxxxx wrote:
      I suggest you to read this example wich does exactly what you need.
      https://github.com/PluginCafe/cinema4d_cpp_sdk/blob/master/source/gui/objectdata_descriptions.cpp#L236
      Where basicly you retrieve a "DescriptionContainer" using GetCustomDataTypeDefault and push it to your description with the correct DescID.
      The example can look a bit scary since it' pretty huge, but it's cover pretty much all kinds of UI possible to add to an object description.
        On 17/11/2017 at 03:02, xxxxxxxx wrote:
        Thank you. i will take a look at it. 🙂
          On 17/11/2017 at 05:27, xxxxxxxx wrote:
          maybe you also want to take a look at some manuals in the SDK Documentation:
          NodeData::GetDDescription() Manual
          Description Manual
          Description Settings Manual
