    MSG_DESCRIPTION_GETBITMAP
    5 Posts 0 Posters 757 Views
      On 01/05/2017 at 15:05, xxxxxxxx wrote:
      Hello!
      Another question translate C++-Code to Python... 😉
      I want to display a Bitmap in the Attribute Manager from a Tag-Plugin.
      In C++ Message() was called with type==MSG_DESCRIPTION_GETBITMAP and the BITMAPBUTTON-id, but in Python it isn't? And what is the equivalent from GeData in GetDParameter() in Python?
      Anyone have a Code-snippet how it works for me?
      I would be glad,
      Mark.
        On 02/05/2017 at 09:44, xxxxxxxx wrote:
        I guess it's like you do in C++ use BitmapButtonStruct.
        https://developers.maxon.net/docs/py/2023_2/modules/c4d/CustomDataType/BitmapButtonStruct/index.html#c4d.BitmapButtonStruct
        (btw there are some errors in the python sdk, then take a look at the c++ one)
        https://developers.maxon.net/docs/cpp/2023_2/class_bitmap_button_struct.html
        And just follow this thread https://developers.maxon.net/forum/topic/2006/1355_customdata-and-gui-messaging&PID=4936#4936
        In python we don't have GeData since a variable is not type dependant.
        So you can do
        a = int()
        b = "hey"
        a = b #now a will be a string with value "hey"
        Hope it's help
          On 03/05/2017 at 02:08, xxxxxxxx wrote:
          Hi Mark,
          I'm afraid MSG_DESCRIPTION_GETBITMAP can't be handled inside NodeData.Message() currently.
          With the Python API, the implementation of NodeData.GetDParameter() can return a c4d.BitmapButtonStruct object for the second item in the tuple. See NodeData.GetDParameter() documentation.
          Unfortunately this is useless as a node can't respond to MSG_DESCRIPTION_GETBITMAP currently.
          gr4ph0s: The errors in c4d.BitmapButtonStruct docs will be fixed.
            On 03/05/2017 at 07:18, xxxxxxxx wrote:
            Hello!
            Thank you, Adam!
            Sadly only now i read your answer, Yannick, after trying half a day 😉
            My attempt was:
                def Message(self, node, type, data) :
                    if type==c4d.MSG_DESCRIPTION_GETBITMAP:
                        if data['id'][0].id==c4d.ID_BITMAP:
                                path = os.path.join(dir, "res", "test.tif")
                                bm = bitmaps.BaseBitmap()
                                bm.InitWith(path)
                                data['bmp'] = bm
                      return False
                def GetDParameter(self, node, id, flags) :
                    if id[0].id == c4d.ID_BITMAP:
                           #BitmapButtonStruct bbs     = BitmapButtonStruct(static_cast<PluginObject*>(node), id, dirty);
                           #t_data          = GeData(CUSTOMDATATYPE_BITMAPBUTTON, bbs);
                        bbs = c4d.BitmapButtonStruct(node, id, 0)
                        return (True, bbs, flags | c4d.DESCFLAGS_DESC_LOADED)
                    return False
                def SetDParameter(self, node, id, t_data, flags) :
                        flags = flags | c4d.DESCFLAGS_DESC_LOADED
            But data in Message was always None...
            Nevertheless thank you for your help 🙂
            Mark.
              On 03/05/2017 at 07:33, xxxxxxxx wrote:
              Note we'll add support for MSG_DESCRIPTION_GETBITMAP inside NodeData::Message() in a future release of Cinema 4D.
