    Using object->Message()
    20 Posts 0 Posters 5.4k Views
      On 31/03/2017 at 09:37, xxxxxxxx wrote:
            Data* data;
            UInt par1 = (UInt)msg.GetVoid(BFM_CORE_PAR1);
            UInt par2 = (UInt)msg.GetVoid(BFM_CORE_PAR2);
            // I use par1 to identify what is passed,
            // par2 contains the data
            if (par1 == something)
                    data = (Data* )par2;
            else if (par1 == somethingelse)
                    data = nullptr;
      Keep in mind that the message is asynchronous. There can be quite some time between the message being sent by one plugin and actually received by the other.
      It is thus possible that when deleting the memory allocation in the sending plugin, the receiving plugin has not yet been triggered. When it does, and it tries to process the obtained pointer, due to the memory already being unallocated this will result in your plugin crashing .
        On 01/04/2017 at 04:44, xxxxxxxx wrote:
        Great, thank you!
          On 03/04/2017 at 02:43, xxxxxxxx wrote:
          And what if I want to pass on a structure like this?
          struct MyStruct
             Int32	index;
             BaseObject* objectLink;
            On 03/04/2017 at 05:28, xxxxxxxx wrote:
            Instantiate the struct (just as you would a class or a POD), and pass the pointer ?
              On 03/04/2017 at 11:03, xxxxxxxx wrote:
              @Pim: Regarding the declaration of a global variable. Even if you don't need it anymore, we should quickly get this right. The correct place to declare a global variable is in one of your .cpp files (and there without extern). When this file gets compiled, the global variable "gets created/allocated (well not really, but for now)" in the resulting object file. In your header you will declare the global variable "extern", so every other cpp file including the header, will not "create" the global variable again, but will know, it has to wait for the global variable coming from another object file. By directly (without extern) declaring the global variable in the header (and I know, I'm responsible for this, because I didn't take time to explain in detail), the global variable will be "created" in every object file, where the source cpp file includes the header. And then the linker will say "uh... oh... already defined" as it won't know, which of the global variables is actually to be used.
              So, short summary to define a global Int32 variable you'd like to access in two different .cpp files:
              // In sourceA.h:
              extern Int32 walter; // Here we just tell the compiler not to try to resolve symbol walter in the currently compiling source/object, but to wait for the linker to resolve it later
              // In sourceA.cpp:
              #include "sourceA.h"
              Int32 walter;  // Here the global variable is actually created and it will take up some space in sourceA.o
              void funcA()
              	if (walter == 0)
              		return;
              	return;
              // In sourceB.cpp
              void funcB()
              	if (walter == 0)
              		return;
              	return;
              For the struct question, well either you have that structure globally or you allocate the struct and store a pointer to it globally (by globally I mean not necessarily global in the sense of the word, but accessible from both classes). When allocating the struct, don't forget to free it on the receiver side and make sure you do not overwrite the pointer before it got received, otherwise you'll end up with a memory leak.
                On 03/04/2017 at 11:40, xxxxxxxx wrote:
                Thanks for all the input and clarifications.
                Everything is working now and I understand what I did wrong and why it is now working (global variables and struct).
                To be sure.
                Is this the best way to initialize a struct?
                		MyStruct* myStruct;
                		myStruct = NewMemClear(MyStruct, 1);
                		myStruct->index = 16;
                		myStruct->objectLink = surface_obj;
                  On 04/04/2017 at 03:04, xxxxxxxx wrote:
                  Yes, though a nullptr check would be appropriate and you should make sure the object is deleted on the receiving end.
                  I haven't used SpecialEventAdd() this way myself. @Andreas
                  is it garuanteed that every message sent will actually be dispatched
                  at some point? Because if it is, say, a queue that swallows events
                  of the same ID, it's not garuanteed.
                    On 04/04/2017 at 05:02, xxxxxxxx wrote:
                    Valid point, Niklas. I checked the code.
                    With SpecialEventAdd() identical events (same messageid and identical parameters p1 and p2) do not get queued, but this shouldn't be a problem in this case. More problematic could be, that events get thrown away, if the event system is overloaded. But I have never seen this under real life conditions.
                      On 04/04/2017 at 07:18, xxxxxxxx wrote:
                      What is the benefit of using:  myStruct = NewMemClear(MyStruct, 1);
                      Opposed to using something more standard looking like this: myStruct = NewObj(MyStruct);
                        On 05/04/2017 at 06:00, xxxxxxxx wrote:
                        @ScottA: I used NewMemClear(), because NewObj() sounded to me more appropriate for objects and not for structures,but - after reading your question - I am not sure anymore.
                        Let's see what the experts say.
                        @NiklasR: "and you should make sure the object is deleted on the receiving end."
                        Is DeleteMem(myStruct) sufficient?
                          On 05/04/2017 at 10:12, xxxxxxxx wrote:
                          @Scott: Well, I wouldn't say there's an advantage. I agree, in general NewObj() is probably preferable, as it can call the constructor for the allocated type. NewMem() on the other hand is mostly used to allocate raw memory (as the docs state) without calling any constructor.
                          @Pim: Yes, DeleteMem() would be sufficient. Saying this will all due caution, assuming you do it correctly (just don't blame me, if you call DeleteMem() in the same thread where you allocated the memory right after sending the message. Which I'd regard a wrong usage, as you'd delete the memory before receiving it in the other thread).
