    Python hyperfile write/read float32
    3 Posts 0 Posters 901 Views
      On 05/06/2016 at 07:49, xxxxxxxx wrote:
      Cinema 4D Version:   R17
      Language(s) :
      When writing out and reading floats I noticed a difference between write/read float32 and write/read float64.
      I have included code using the 32 variant. The double precision seems to work OK, but I would expect that while less precise, the 32 bit variant to "closely" match the expected value.
      Write/Read Float32
      writing -> version: 0.4
      reading -> version: -1.58818683921e-23
      Write/Read Float64
      reading -> version: 0.4
      def WritePreset(self) :
            testversion = 0.4
            folder, filename = os.path.split(__file__)
            fn = os.path.join(folder, 'preset')
            hf = c4d.storage.HyperFile()
            if hf.Open(ident=12345, filename=fn, mode=c4d.FILEOPEN_WRITE, error_dialog=c4d.FILEDIALOG_NONE) :
                print 'writing -> version:', testversion
                if not hf.WriteFloat32(testversion) :
                    print 'Failed writing'
                hf.Close()
                print 'Failed open hyperfile', hf.GetError()
        def ReadPreset(self) :
            if os.path.isfile(fn) and hf.Open(ident=12345, filename=fn, mode=c4d.FILEOPEN_READ, error_dialog=c4d.FILEDIALOG_NONE) :
                ver = hf.ReadFloat32()
                print 'reading -> version:', ver
                hf.Close()
        On 13/06/2016 at 06:34, xxxxxxxx wrote:
        you have found a bug in the argument parsing of WriteFloat32(). Sorry!
        The only workaround I have for now is to use WriteFloat64() instead. The bug will be fixed in one of the next releases.
          On 15/06/2016 at 12:19, xxxxxxxx wrote:
          Thank you Andreas
