    FIT_H or SCALE_H in description files
    12 Posts 0 Posters 1.4k Views
      On 03/05/2016 at 08:31, xxxxxxxx wrote:
      Cinema 4D Version:   17
      Language(s) :     C++  ;   PYTHON  ;
      From what I experience, there are limitations in what I can do with a layout description file for a DIALOG or for a CONTAINER.
      I don't seem to be able to use SCALE_H or FIT_H or even ALIGN_LEFT or CENTER_H in GROUP.
      I'm creating a Tag plugin and I would like to have an interface that has two columns. The left column would have a IN/EXCLUDE field and the right column would have a set of sliders, combo-boxes, etc, arranged vertically.
      Something like this:
      Is this even possible in CONTAINER descriptors?
      Where can I find the information about the limitations/differences between DIALOG and CONTAINER .res layout description files?
        On 03/05/2016 at 08:38, xxxxxxxx wrote:
        Oh, by the way, I know I can use LAYOUTGROUP
        However, I'm getting this:
        Everything is flushed to the left and I wanted it to span the whole with of the Attribute Manager.
        It seems that no combination of SCALE_H or FIT_H does the trick.
        And I can't even seem to be able to set those attributes to groups.
          On 03/05/2016 at 12:10, xxxxxxxx wrote:
          I ran into this same thing a very long time ago. And this was the only way I could do it.
          This is the .res file from my QuickSteps plugin:
          //This is an example of using LAYOUTGROUP to format two columns of GUI's
          //The use of SEPARATOR Groups is the only way I found to push the second column GUI's over to the right
          CONTAINER tquicksteps
          NAME tquicksteps;
          INCLUDE Texpression;
          INCLUDE Obase;
            GROUP ID_TAGPROPERTIES
             STATICTEXT MYTEXT {ANIM OFF; } //ANIM OFF hides the set key option from the user
              GROUP    //The master Group
                LAYOUTGROUP; COLUMNS 6;
                GROUP
                  BUTTON BTN_BAKE_STEPS {}
              REAL NUMofGUIS {MIN 0.0; MAX 100.0; STEP 1;} //STEP controls the amount the values increase using the arrows
              SEPARATOR { LINE; }
                GROUP  //Used to space out the other two groups horizontally
                SEPARATOR { LINE; }
                SEPARATOR { LINE; }
                SEPARATOR { LINE; }
                SEPARATOR { LINE; }
                GROUP
                  BUTTON BTN_BAKE_KEYS {}
              REAL NUMofKEYS {MIN 1.0; MAX 100.0; STEP 1;} //STEP controls the amount the values increase using the arrows
              BUTTON BTN_DELETE_KEYS {}
            On 03/05/2016 at 14:42, xxxxxxxx wrote:
            Thank you, Scott.
            But it is not working for me
            This is my .res file (I tried to follow your example but it still appears like in the image I posted above).
            CONTAINER vertexmapmix
                 NAME vertexmapmix;
                 INCLUDE TBase;
                      BOOL VMM_ONOFF {}
            LINK VMM_VERTEXMAP { ACCEPT {5682;} }
            GROUP
                           LAYOUTGROUP;
                           COLUMNS 6;
            GROUP
                                IN_EXCLUDE VMM_ATOMS
            NUM_FLAGS 0;
                                    INIT_STATE 0;
                                     ACCEPT {5682;}
                                SEPARATOR { LINE; }
            GROUP
                           SEPARATOR { LINE; }
            GROUP
                           SEPARATOR { LINE; }
            GROUP
                           SEPARATOR { LINE; }
            GROUP
                           SEPARATOR { LINE; }
            GROUP
                                BOOL VMM_ATOM_ONOFF {}
                                LONG VMM_ATOM_MIX { CYCLE { VMM_MIX_NORMAL; VMM_MIX_MULT; VMM_MIX_MIN; VMM_MIX_MAX; VMM_MIX_ADD; VMM_MIX_SUB; } }
              On 03/05/2016 at 16:10, xxxxxxxx wrote:
              My notes about this are very poor. So I can't offer much more help.
              The basic idea is that you add dummy groups between your groups of gizmos.
              It does push things to the right. But it's a hack, and I don't know how much control you'll get from it.
              This was the only way I could figure out how to spread out two columns of gizmos horizontally in a node based AM window.
              Here's a slightly differnt/simpler example:
              CONTAINER MyTag_dec  //Container Must! be set to the name of your .h file
              NAME MyTag_dec;
              INCLUDE Obase;
              GROUP
                    LAYOUTGROUP; COLUMNS 3;
                         GROUP
                            IN_EXCLUDE MY_IE{}
                        GROUP
                          STATICTEXT { }  //<--Dummy gizmo for spacing. This is not declared in the .h or str files
                        GROUP
                            STATICTEXT MY_TEXT {}
                            BOOL MY_CHECKBOX{}
                            REAL MY_NUMEDIT{MIN 1.0; MAX 100.0; STEP 1;}
                            BUTTON MY_BTN{}
                On 03/05/2016 at 17:00, xxxxxxxx wrote:
                This is the .res file I tried:
                     NAME vertexmapmix;
                     INCLUDE TBase;
                          BOOL VMM_ONOFF {}
                SEPARATOR { LINE; }
                GROUP
                               COLUMNS 3;
                BUTTON VMM_CREATEVERTEXTAG { NAME VMM_CREATEVERTEXTAG_TEXT; }
                BUTTON VMM_SELECTVERTEXTAG { NAME VMM_SELECTVERTEXTAG_TEXT; }
                SEPARATOR { LINE; }
                          GROUP
                GROUP
                NUM_FLAGS 0;
                                        INIT_STATE 0;
                ACCEPT {5682;}
                GROUP
                                    { STATICTEXT {} }
                GROUP
                                    LONG VMM_ATOM_MIX { FIT_H; CYCLE { VMM_MIX_NORMAL; VMM_MIX_MULT; VMM_MIX_MIN; VMM_MIX_MAX; VMM_MIX_ADD; VMM_MIX_SUB; } }
                SPLINE VMM_ATOM_CURVE
                                              SHOWGRID_H;
                                              SHOWGRID_V;
                                              GRIDSIZE_V 8;
                                              X_MIN 0.0;
                                              X_MAX 1.0;
                                              Y_MIN 0.0;
                                              Y_MAX 1.0;
                                              EDIT_H;
                                              EDIT_V;
                And this is what I get:
                  On 03/05/2016 at 17:48, xxxxxxxx wrote:
                  Well...It's better than it was.
                  At least now they aren't both squished up against each other to the left.
                  Maybe you can try a different kind of dummy gizmo to see if it pushes the second column farther to  the right. Or maybe add another group. Or maybe a combo of the two.
                  The Maxon support guys might know of a better way.
                  It was along time ago and I have a bad memory. But I'm fairly sure I remember they said that there was no way to format columns in a Node based AM window with the SDK.
                  And I typically only invent terrible hacks like this when there is no other choice.
                    On 03/05/2016 at 17:58, xxxxxxxx wrote:
                    Yes, I just found a few minutes ago another post (that I created sometime ago) and the final verdict was that it is not possible
                    So, I re-arranged my layout and, although not as pretty and efficient as the one I wanted, it is not bad.
                    But it has no columns
                      On 03/05/2016 at 18:13, xxxxxxxx wrote:
                      These might help you.
                      STATICTEXT { JOINENDSCALE; }
                      STATICTEXT { JOINEND; }
                      These will tell the previous widget to use up its space to the right of the widget.
                      Here is an example use.
                      GROUP
                           COLUMNS 3;
                      SEPARATOR { LINE; }
                           REAL MY_VALUE { MIN 0.1; MINSLIDER 1; MAXSLIDER 100; CUSTOMGUI REALSLIDER; SCALE_H; }
                           BUTTON MY_BUTTON { ALIGN_LEFT; }
                           BOOL MY_BUTTON2 { }
                           STATICTEXT { DUMMY; }
                      The SEPARATOR line will go over all 3 columns.
                      The Real value will be a slider that uses up most of the space but puts a button at end of it.
                      The last button will just be in a row by itself with the next 2 columns empty.
                        On 03/05/2016 at 18:25, xxxxxxxx wrote:
                        Thank you,kbar.
                        I will look into it tomorrow.
                        It is already very late here (2:24 a.m.)
                          On 03/05/2016 at 21:26, xxxxxxxx wrote:
                          This is a list of all the known flags that STATICTEXT can have, based on what is currently used in C4D R17.
                          http://dev.gamelogicdesign.com/Description/FindElementFiles?elem=STATICTEXT
                            On 04/05/2016 at 04:45, xxxxxxxx wrote:
                            I have been trying but I still can't make it work like I want
                            This is the type of layout I need:
                            So, I guess I really need to use LAYOUTGROUP. But the LAYOUTGROUT doesn't expand to the whole width of the window.
