    Get BaseObject from ObjectData
    3 Posts 0 Posters 364 Views
      On 10/02/2016 at 04:57, xxxxxxxx wrote:
      Cinema 4D Version:   R17
      Here is the newbie again, I've managed to create my object derived from ObjectData but what if I want to move it from inside itself?
      Moving it seems to be trivial using BaseObject* functions but I cannot find the way to get it.
      Regards and thank you in advance again!
        On 10/02/2016 at 05:38, xxxxxxxx wrote:
        From inside your ObjectData-derived class, you can use either the GeListNode* node passed to the method in the class:
        Bool MyObjectData::Message(GeListNode* node, Int32 type, void* data)
        	if (!node)
        		return FALSE;
        	BaseObject*	pObject =	static_cast<BaseObject*>(node);
        	// etc.
        	return SUPER::Message(node,type,data);
        Or you can use the NodeData::Get() method:
        Bool MyObjectData::MyMethod()
        	GeListNode*	node =	Get();
        	if (!node)
        		return FALSE;
        	// etc.
          On 10/02/2016 at 10:02, xxxxxxxx wrote:
          Thank you second method is perfect for me
