    Crash in R17 when Shader is added
    5 Posts 0 Posters 680 Views
      On 01/11/2015 at 10:18, xxxxxxxx wrote:
      Hi there,
      you can find the shader plugin on GitHub here. If you open the shader list in a material and add
      a "PyShader" to a material channel, Cinema 4D crashes (instant-exit on Windows). This happens only
      in R17, not in R16 or R15.
      Any idea what's the reason behind it? TIA
      -N
        On 01/11/2015 at 11:37, xxxxxxxx wrote:
        Update: Probably related to https://developers.maxon.net/forum/topic/9145/12137_undo-loses-stored-data&PID=48189#48189
          On 02/11/2015 at 03:42, xxxxxxxx wrote:
          Hi Niklas,
          can you do us a favor? We'd like to be sure, that it's exactly the same problem (and not another one that may need further investigation). Could you do a test without your CopyTo() to see, if the crash is fixed?
            On 02/11/2015 at 23:53, xxxxxxxx wrote:
            Hi Andreas,
            It works when I comment out the CopyTo() method.
              On 03/11/2015 at 00:08, xxxxxxxx wrote:
              Thanks for testing, Niklas. That's good to know.
