    CustomGui DescID [SOLVED]
    SDK Help
    0
    • H
      On 06/08/2015 at 01:10, xxxxxxxx wrote:
      Cinema 4D Version:   R16
      Greetings !
      I have created a custom gui and i use it in resource file as:
      LONG UPPER_MENU { CUSTOMGUI INTERACTIVE_AREA; }
      LONG .... { CUSTOMGUI INTERACTIVE_AREA; }
      LONG LOWER_MENU { CUSTOMGUI INTERACTIVE_AREA; }
      How can i get the values each menu ID in the constructor of the customgui subclass?
      I use many menus that way and i want to handle them differently during creation.
      Cosntructor:
      MyCustomGui::MyCustomGui(const BaseContainer &settings,CUSTOMGUIPLUGIN *t_plugin)
      I need something like String str=settings.GetString(DESC_IDENT); but this one returns the string.
      I need the DescID. I looked at the ids i can pass but no one returns what i want.
      Thank you very much for your time.
      • H
        On 06/08/2015 at 01:19, xxxxxxxx wrote:
        you can do this through a CustomDataType connected to your CustomGui, at least this is what I've done in my case and works fine.
        • H
          On 06/08/2015 at 02:17, xxxxxxxx wrote:
          Hello.
          The function getCustomDataType needs the id of an element as parameter.
          What I need to find is this ID.
          I have many elements defined as:
          LONG MY_MENU { CUSTOMGUI INTERACTIVE_AREA; }
          I need the value of MY_MENU  inside the constructor of interactive area custom gui.
          Thank you.
          • H
            On 07/08/2015 at 02:19, xxxxxxxx wrote:
            sorry for the late reply.
            now I kinda understand what you want to do, you wanna react in your user area depending on the MY_MENU integer value.
            check this, done by Niklas, https://github.com/nr-plugins/example-tristate-gui/tree/e090322e5ff3aca795254d74e1021213d7cf39e5
            here is the highlighted interesting area, https://github.com/nr-plugins/example-tristate-gui/blob/e090322e5ff3aca795254d74e1021213d7cf39e5/src/TriStateGui.cpp#L195-L233
            m_ua is a member, representing your user area, and here it can "see" what the value is, so you can react according to this.
            • H
              On 07/08/2015 at 03:36, xxxxxxxx wrote:
              I'm not sure, it is a good idea to react on specific description IDs in a CustomGUI. After all the CustomGUI can be used for every description parameter of a given type. So you can't actually know in advance for which IDs the CustomGUI will be used.
              Instead I propose to have a CustomProperty on the CustomGUI, where an integer can be specified to choose the desired behavior.
              • H
                On 07/08/2015 at 04:01, xxxxxxxx wrote:
                @Andreas, this is one of the reasons I made my CustomGui hidden "only me can use it" , and used it privately inside my CustomDataType
                • H
                  On 26/08/2015 at 10:06, xxxxxxxx wrote:
                  @peterakos: Have you been able to get going?
                  • H
                    On 26/08/2015 at 13:30, xxxxxxxx wrote:
                    Greetings !
                    Yes i have managed to find a workaround to my problem.
                    Thank you very much.
